DLM/GEA Check requested please
mrshed
Just switched over to Plusnet about 2 weeks ago but my speed has dropped by around 20% - from around 36/37Mb to 30/31.
It may be too early in terms of the DLM but can someone check what my DLM band is and also any GEA check?
Can my DLM be reset or forced up at all to try and match my previous speeds...?
My SNR is hovering around 6.
Thanks!
2 REPLIES 2
Fixes: 417
Re: DLM/GEA Check requested please
When you change provider Openreach reset the DLM to 6dB. If your line will support it then this should drop to around 3 with a resultant increase in speed. Unless your line is banded you just have to be patient and wait for it to update automatically.
OskarPapa
Fixes: 65
Thanks for your post @mrshed.
On running a GEA test we can see that the SNR is currently at 3db with the banding for the line looking correct:
GEA Test Detail
Circuit ID <REDACTED> Service ID <REDACTED>
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 27.7 Mbps
Upstream Speed 5.5 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Detected
Estimated Line Length In Metres 975.4
Upstream Rate Assessment Low
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence No Timing Information
Interference Location Customer Premise
Interference Observed In Days 2
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-05-10T12:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 25.4 Mbps 37.5 Mbps 30.3 Mbps
Up Stream Line Rate 5.3 Mbps 7.1 Mbps 6.0 Mbps
Up Time 0.0 Sec 900.0 Sec 897.2 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-05-23T10:36:38Z 2019-05-23T10:51:38Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
The only slight concern is that it's detected CrossTalk, however on testing the line further we aren't seeing anything that could be construed as an issue, with copper line tests showing clear.
We'd recommend giving it another week or so for the line speed to pick up.
