DD-WRT or Tomato on a Technicolor 582n
HLatte
Hi All,
By any chance did somebody installed DD-WRT or Tomato firmware on a plusnet router Technicolor 582n?
I'm thinking to use it as a WiFi replicator now that I bought a better router  Wink as my main access point.
Tks for any help
HL
1 REPLY 1
bill888
Champion
Fixes: 38
Re: DD-WRT or Tomato on a Technicolor 582n
fyi, I don't believe there is any DD-WRT or Tomato support for TG582n.
There is some early development on putting OpenWRT onto the TG582n.  Unfortunately, the procedure requires soldering and wiring the TG582n to a PC with a parallel port.  There are no fully built images for the TG582n too.  ie.  you have to build it yourself.
https://forum.openwrt.org/viewtopic.php?id=46784
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
