DD-WRT or Tomato on a Technicolor 582n
- Re: DD-WRT or Tomato on a Technicolor 582n
23-10-2015 12:24 PM
Hi All,
By any chance did somebody installed DD-WRT or Tomato firmware on a plusnet router Technicolor 582n?
I'm thinking to use it as a WiFi replicator now that I bought a better router as my main access point.
Tks for any help
HL
Tks for any help
HL
Message 1 of 2
(5,029 Views)
1 REPLY 1
23-10-2015 12:46 PM
fyi, I don't believe there is any DD-WRT or Tomato support for TG582n.
There is some early development on putting OpenWRT onto the TG582n. Unfortunately, the procedure requires soldering and wiring the TG582n to a PC with a parallel port. There are no fully built images for the TG582n too. ie. you have to build it yourself.
https://forum.openwrt.org/viewtopic.php?id=46784
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 2 of 2
(4,449 Views)
