D/L speed
Valerietudor
D/L speed
I upgraded to 'Unlimited Fibre' on the 7th, the engineer said my D/L speed would be 30Mb, I currently only have 18Mb, I expected it to go up after the first 5 days, but nothing has changed, is there anything I can do?
Andrue
Re: D/L speed
Quote from: Valerietudor
If someone told you there was a 'settling in' period they misinformed you. Connections run at full speed from day one and if they do anything they drop slightly over the first few days.
Anyway are you running tests wired or wireless?
Fixes: 167
Re: D/L speed
The engineer wasn't correct I'm afraid, your line is actually in sync at 19.5Mb which is within the estimate range for your line of 16.1-23.1Mb/s. Your line is reporting as being around 1.5Km from the cabinet, so that's the speed I'd be expecting.
 Chris Parr
 Plusnet Staff
