Cyberghost
patti
Cyberghost
Hi, anyone used a VPN called Cyberghost? also is it compatible with an Acer R11 Chromebook? any info/comments on how easy it is to install or anything better than Cyberghost would be much appreciated.
1 REPLY
southerner
Re: Cyberghost
This might help https://www.bestvpn.com/best-chromebook-vpn/ Also try Googling 'Chrome OS VPN' for more options.
The link suggests VPNs that are Chrome OS friendly where they supply a Chrome extension that you would use to connect to the VPN.
Other VPN companies you can create connections manually to but usually it's using out of date protocols so you're not as secure as you would be using a VPN company's app or Chrome extension as in this instance.
Hope that helps.
