Current Line Speed too low
- Current Line Speed too low
03-04-2021 10:20 PM - edited 03-04-2021 10:21 PM
Hi.
I haven't had any recent issues with my FTTC/VDSL2 service, and my connection is generally rock solid. I had reason to run a BT Wholesale speed test a few weeks ago, and also checked my Current Line Speed, which was below what I believe it should be compared to the BTW test. I just rechecked it to see if it had caught up, and was disappointed to note that it had not changed.
PN Current Line Speed (Download): 56Mbps
BTW IP Profile for your line is 59.35 Mbps
Stats from my router show the connection has been up for nearly 118 days at time of posting:
B0 Line Rate - Upstream (Kbps) 10695
B0 Line Rate - Downstream (Kbps) 64822
Connection Time 117 Day(s) 19:22:34
Could the PN Current Line Speed please be increased to match the BT IP Profile?
Re: Current Line Speed too low
04-04-2021 7:48 AM
@Jaggies Have you paid Plusnet £5 to get a Static WAN IP address? If the answer is no then the current line speed will have no effect on your actual throughput speed. The Current Line Speed is a confusing value that isn't actually a speed at all, but a legacy Plusnet profile that in the past limited throughput speed. It is supposed to track changes in the BT IP profile but sometimes doesn't. Yours is a bit low but it would only affect your speed if you have a Static IP as that uses a different network connection to dynamic IP customers.
04-04-2021 12:48 PM
