Current Line Speed stuck
smithcomputers
If anyone is around could they kick my line speed up please, It says 7.8 and I am connected at 9975. It is very quick to drop if you have a one off event but it never seems to go back on its own. Many thanks in advance for any help.
Cheers
                Mike..
Fixes: 68
Re: Current Line Speed stuck
Hey Mike, the profile is set to 9mbps on our side already.
Are you connecting over LAN or WiFi?
 Adam Walker
smithcomputers
Hi Adam, I connect via lan only and it must have changed inbetween me asking and you checking as I have just checked myself and can see it is at 9 but when I asked it was only 7.8, Would you believe it it must have done it automatically as it should. Thank you very much for checking for me though it is very much appreciated. Thanks again....
Mike...
Fixes: 414
Automation is a brilliant thing. Grin
Looks like it changed at 15:24 on the day you posted.
Please let us know if you need any further assistance Mike.
