Current Line Speed 21
BL-TZ
After noticing a drop in speed yesterday morning 36Mbps down to 30Mbps, which was solved with a quick reboot of the Openreach modem (I put this down to the recent maintenance). I've seen that the Current Line Speed shown in the Members Centre has dropped to 21 (It's been at 38 for over 18 months). It doesn't appear to have affected my download speed which has returned back to 36Mbps. However I'm curious as to how I'm getting full speed if the line has dropped?
anniesboy
Re: Current Line Speed 21
I am getting similar result, current line speed showing 21.
Im actually getting 33.
SpendLessTime
Aspiring Hero
Fixes: 54
On FTTC, the Plusnet current line speed is only applied when the router logs into Plusnet to create a PPP session. So next time you reboot the router, or disconnect/connect from the router's admin page then that speed will be applied.
Plusnet Staff
Plusnet Staff
Fixes: 159
Only if they are on the old network Wink The profile shown there is largely irrelevant on the new network.
 Chris Parr
 Plusnet Staff
BL-TZ
Well I've noticed that the gateway checker is giving me errors too so does that mean that I'm on the new network?
SpendLessTime
Aspiring Hero
Fixes: 54
@BL-TZ
What does the output from the gateway checker actually say?
BL-TZ
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Issues topic in the Community forums will help us to diagnose the problem.
core2-hu0-18-0-0.colindale.ukcore.bt.net (62.172.103.16) 3.692 ms
SpendLessTime
Aspiring Hero
Fixes: 54
That is the new network
And that error was reported on 17-06-2016 so still not fixed.
BL-TZ
Fair enough, I've seen plenty of references to the 'new network' just to need to read up on what it all means I guess Smiley
SpendLessTime
Aspiring Hero
Fixes: 54
