Cross talk and sync speed lost
- Cross talk and sync speed lost
27-07-2015 11:57 AM
Re: Cross talk and sync speed lost
27-07-2015 12:06 PM
Long answer, someone more technical will no doubt answer. It can be one new connection knocks several Mbps off you, when a dozen others didn't make any significant difference. Or the one that does the damage could be the first, and the next dozen don't make it much worse.
27-07-2015 12:11 PM
Cheers.
27-07-2015 12:37 PM
In other words, screening the coppers in the cabinet won't make any difference?
27-07-2015 12:48 PM
It's why i hope that Vectoring gets rolled out someday soon as it eliminates crosstalk and then hopefully my full speed will return.
As for your loss, 1Mb loss could be crosstalk or maybe due to very low interleaving being applied it's hard to say, and I wouldn't laugh a loss is a loss in my book although there are some members here who would say other wise.
27-07-2015 12:58 PM
27-07-2015 1:02 PM
27-07-2015 1:05 PM
27-07-2015 1:11 PM
As I say it was a couple of days after the OR engineer fixed a "loose connection" in the cabinet for a phone line problem that things dropped. The connection has dropped a few times since, but with no loss of sync or drop in profile.
27-07-2015 8:15 PM
27-07-2015 8:18 PM
28-07-2015 6:02 PM
28-07-2015 11:00 PM
28-07-2015 11:03 PM
29-07-2015 2:28 AM
