Crippling Speeds, Router Error Log, Help
- Crippling Speeds, Router Error Log, Help
22-02-2019 3:39 PM
Wifi cripples to kbps and following error log, Please help.
Feb 20 01:58:52 kernel: br0: port 2(ra0) entered disabled state
Feb 20 01:58:54 kernel: ch36 bssid=24:20:c7:61:bb:fd
Feb 20 01:58:54 kernel: ch36 bssid=26:20:c7:61:bc:fe
Feb 20 01:58:54 kernel: ch36 bssid=26:20:c7:61:bc:ff
Feb 20 01:58:54 kernel: ch44 bssid=48:d3:43:ef:52:b7
Feb 20 01:58:54 kernel: ch44 bssid=c0:05:c2:99:6b:0f
Feb 20 01:58:54 kernel: =====================================================
Feb 20 01:58:54 kernel: Channel 36 : Dirty = 210, False CCA = 2, Busy Time = 0, Skip Channel = FALSE
Feb 20 01:58:54 kernel: Channel 40 : Dirty = 160, False CCA = 5, Busy Time = 0, Skip Channel = FALSE
Feb 20 01:58:54 kernel: Channel 44 : Dirty = 140, False CCA = 54, Busy Time = 0, Skip Channel = FALSE
Feb 20 01:58:54 kernel: Channel 48 : Dirty = 64, False CCA = 1, Busy Time = 0, Skip Channel = FALSE
Feb 20 01:58:54 kernel: Rule 1 CCA value : Min Dirtiness ==> Select Channel 48
Feb 20 01:58:54 kernel: Min Dirty = 64
Feb 20 01:58:54 kernel: ExChannel = 44 , 0
Feb 20 01:58:54 kernel: BW = 40
Feb 20 01:58:54 kernel: br0: port 2(ra0) entered listening state
Feb 20 01:59:09 kernel: br0: port 2(ra0) entered learning state
Feb 20 01:59:24 kernel: br0: topology change detected, propagating
Feb 20 01:59:24 kernel: br0: port 2(ra0) entered forwarding state
Feb 20 02:31:59 NTP Client: Synchronizing time to time.nist.gov.
Feb 21 02:31:59 NTP Client: Synchronizing time to pool.ntp.org.
Feb 21 02:32:04 NTP Client: System time changed, offset: 2.473500s
Feb 22 02:32:02 NTP Client: Synchronizing time to time.nist.gov.
Feb 22 02:32:04 NTP Client: System time changed, offset: 1.257603s
Feb 22 03:18:15 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN/WLAN]
Feb 22 03:18:15 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
Feb 22 03:20:20 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN/WLAN]
Feb 22 03:20:20 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
Re: Crippling Speeds, Router Error Log, Help
22-02-2019 4:39 PM
Sorry to hear you're having issues with the wireless side of things.
The logs you've provided aren't showing any particular issues although you appear to be using a 3rd party router so it may be worth getting the manufacturer to confirm.
Have you tried changing the wireless channel?
22-02-2019 4:41 PM
Yes, its currently on Auto and chooses 13, i have used 13 for years. Everything ok wired n 5ghz.
22-02-2019 5:29 PM
22-02-2019 6:25 PM - edited 22-02-2019 6:33 PM
Its been on 13 for 5 years plus. Sudden drop to kbps varies during day/night.
Goes from kbps and crippling use of net. Then magically full whack 45mb sometimes. in between it rises straight to 45mb and decreases to kbps in speedtests.
HOT VLAN???
22-02-2019 8:55 PM - edited 22-02-2019 8:57 PM
Hi @Faizan786,
I'm sorry that you're experiencing connection problems. I've tested your line but the test hasn't picked up any problems from here and your line is currently syncing at 47mbps, which is slightly above the estimates of 30.7 - 45mbps:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 47.0 Mbps | ||||
Upstream Speed | 6.8 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 883.5 | ||||
Upstream Rate Assessment | Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-55M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2019-02-09T21:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 47.0 Mbps | 47.0 Mbps | 47.0 Mbps |
Up Stream Line Rate | 6.7 Mbps | 6.7 Mbps | 6.7 Mbps |
Up Time | 899.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-22T20:25:08Z | 2019-02-22T20:40:08Z |
Ingress Code Violation | 0 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
And you're not connected to a hot VLAN:
VLAN Analysis | |||
Circuit ID: | NA | Service ID: | BBEUXXXXXXXX |
Telephone NO.: | NA | Test Executed On: | 22-02-2019 20:49:41 |
Date | HOT VLAN(Yes/No) | Action | Fix Date |
22-02-2019 | NO | ||
21-02-2019 | NO | ||
20-02-2019 | NO | ||
19-02-2019 | NO | ||
18-02-2019 | NO | ||
17-02-2019 | NO | ||
16-02-2019 | NO |
If you're not experiencing any problems on wired connections, I'd recommend contacting the router manufacturer so that they can further assist with the wireless problems. Alternatively, if you've still got your Plusnet router it might be worth swapping to it.
23-02-2019 3:26 PM
Any particular reason why you're not using the Plusnet Hub One? The Asus only has a 2.4GHz radio, so is less capable on paper from a wi-fi perspective.
