Could this be a faulty TG 582n??
- Re: Could this be a faulty TG 582n??
21-02-2016 8:08 AM
Lost wi-fi to our Internet Radio and Smart TV - expect that wi-fi to mobile phones work fine, plus ethernet connection. (NB: Line is stable for for 6 weeks at a time)
If I reboot the TG582 router all is well again for a few days then the issue comes back - well it has twice.
Any clues to the solution?
21-02-2016 9:44 AM
I suspect the issue your seeing is not unusual with the Technicolor router and devices which have long periods in sleep mode.
21-02-2016 9:56 AM
Should have change them all to "always use the same IP address", or just the ones showing '0.0.0'?
Would the IP address of the device stay the same although I don't use a static IP with Plusnet?
(It is not clear which are the tv & radio from the devices shown!!!)
21-02-2016 10:16 AM
21-02-2016 10:27 AM
Any other suggestions? Is this a known issue with the new firmware?
21-02-2016 1:32 PM
21-02-2016 2:05 PM
The software update is 10.2.5.2.FO
Any further ideas?
21-02-2016 11:53 PM
Are you familiar with Telnet? You need Telnet to be activated on your OS.
Open a cmd window and type telnet 192.168.1.254
You'll then be prompted for a username ..... admin
and then the password (the TG582n's serial number)
At the telnet prompt, enter the following commands.
dns server config WANDownSpoofing = disabled
dns server debug spoof clear
dns server debug spoof list
saveall
exit
22-02-2016 7:36 AM
Again thanks for your suggestions.
22-02-2016 12:46 PM
