Could someone check my connection stats and line please
michellegoodwin
Recently noticed that our speed is way below estimate given by plusnet and the BT DSL checker for a none impacted line, could someone look my line stats over?
Fixes: 235
Re: Could someone check my connection stats and line please
Our tests aren't showing any obvious issues although your speeds are in the middle of the impacted range.
If you raise a fault here we'll see what we can do.
 Matthew Wheeler
michellegoodwin
Thanks for the reply, any reason it is within the impacted range?
