Could someone check my connection stats and line please
- Re: Could someone check my connection stats and li...
10-04-2017 2:22 PM - edited 10-04-2017 2:23 PM
Recently noticed that our speed is way below estimate given by plusnet and the BT DSL checker for a none impacted line, could someone look my line stats over?
Message 1 of 3
(615 Views)
2 REPLIES 2
Re: Could someone check my connection stats and line please
10-04-2017 2:28 PM
Our tests aren't showing any obvious issues although your speeds are in the middle of the impacted range.
If you raise a fault here we'll see what we can do.
Message 2 of 3
(605 Views)
10-04-2017 6:34 PM
Thanks for the reply, any reason it is within the impacted range?
Message 3 of 3
(569 Views)
