Could my speed be better?
- Could my speed be better?
Re: Could my speed be better?
22-12-2016 9:13 PM
I'm sorry. I think you're pulling my chain: " One of my faults colleagues best explained to me; the sync as a rounded up figure, and the line rate as the sync over time."
A rounded up figure? That'll be Venus de Milo then. A "figure"? What figure?
You must be really smart if you understand things like that.
22-12-2016 9:28 PM
I'm looking at Zen, AAISP and IDNet atm, then working out early termination to be honest. It's just not worth the hassle.
23-12-2016 1:39 PM
@aj007 wrote:
I've set the command that you mentioned over on kitz so I've capped the downstream to 60.
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 17a
G.Vector: Disable
Traffic Type: PTM Mode
Link Uptime: 0 day: 0 hour: 17 minutes
VDSL Port Details Upstream Downstream
Line Rate: 20.063 Mbps 59.999 Mbps
Actual Net Data Rate: 19.999 Mbps 60.000 Mbps
Guess we'll have to wait and see if the GEA test registers the change. IP profile is still 62.04
GEA Service Test coming up...
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU######### |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 57.4 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 498.0 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Profile Name | 0.128M-67M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2016-12-10T13:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 60.0 Mbps | 66.9 Mbps | 66.6 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 200.0 Sec | 900.0 Sec | 899.1 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2016-12-23T13:15:12Z | 2016-12-23T13:30:12Z |
Ingress Code Violation | 0 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Whatever you've changed in your router has affected the sync.
23-12-2016 1:53 PM - edited 23-12-2016 1:58 PM
So the GEA test ran and I've found out a few things.
1. Downstream speed on the GEA test is an actual speed test without a doubt. GEA reports 57.4, and my speed test is pretty much bang on 57.4.
2. The parameters section at the bottom is the line rate which should correlate to the router (which is correctly 60, and was correctly 66.997 before)
3. My IP profile hasn't changed.... Still 62.1
4. Router stats as follows:
Mode: VDSL2 Annex B
G.Vector: Disable
Link Uptime: 0 day: 17 hours: 50 minutes
Trellis Coding: ON ON
SNR Margin: 7.4 dB 9.7 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 7.0 dBm 13.0 dBm
Receive Power: -8.6 dBm -3.5 dBm
Actual INP: 0.0 symbols 52.0 symbols
Total Attenuation: 0.0 dB 17.2 dB
Attainable Net Data Rate: 23.235 Mbps 75.192 Mbps
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 5.2 21.6 32.6 N/A N/A 12.1 27.7 42.2
Signal Attenuation(dB): 5.2 20.9 31.9 N/A N/A 13.4 27.5 42.2
SNR Margin(dB): 7.1 7.4 7.3 N/A N/A 9.7 9.7 9.7
TX Power(dBm): -3.5 -21.5 6.6 N/A N/A 9.7 7.8 6.9
So reflecting on this, the earlier GEA tests weren't correctly reporting my downstream rate (GEA 64.1, but my actual results were 60ish). Additionally the IP profile hasn't changed at all which is strange.
I'll release the sync restriction and see if it picks up to 67 again
23-12-2016 2:00 PM
Thanks for providing that - Interesting.
1) We know for a fact that the line is currently syncing at 60 Mbps.
2) Noted that Downstream Speed reported by the GEA test is not the actual sync speed.
3) Noted that GEA has picked up the EU is currently syncing at 60Mbps (see under Down Stream Line Rate)
The EU deliberately capped his line to 60Mbps on his side so we could see what effect the changes had on GEA test
It therefore looks like the Downstream Speed reported by GEA test is throughput speed and NOT sync speed.
ETA my post crossed with aj007s
23-12-2016 2:03 PM - edited 23-12-2016 2:12 PM
Just for others who are interested, here's the thread over on Kitz
Kitz do you know the CLI command to uncap the sync? :)7
Edit: Just saw your post on Kitz, thanks!
Out of interest, how did the GEA tests before I capped my line test at 64.1 when my IP profile is 62.04? Does the GEA test bypass the IP profile or something?
23-12-2016 2:23 PM - edited 23-12-2016 2:25 PM
Not sure about bypassing the IPprofile... but some of the tests will bypass the ISP network.
Which in turn makes me ponder on something else. What is the Plusnet 'Stable rate' for aj007's line.
PS. Should point out that the Stable rate has absolutely not effect on the rate at which the line can sync at and will not be limiting the sync speed. It can only affect throughput.
23-12-2016 2:25 PM
Current - 64 mbps
Worth dropping the connection altogether for an hour like ejs recommended?
23-12-2016 3:10 PM
Just worth noting, the connection profile on your account (current line speed in your Member Centre) won't be making much of a difference to your throughput as your service is provisioned on our new network.
The profile should automatically update to reflect your new sync level over the next few days.
23-12-2016 3:31 PM
64.1/67 = 0.9567164179 = 95.67%
57.4/60 = 0.9566666666 = 95.67%
I think those percentages being the same is not a coincidence. There must be something going on with the "Downstream Speed" reported by the GEA test that we do not know about, and I don't think it's a fault or malfunction. It's possibly related to the "Retransmission High" profile, there are various parameters in G.998.4 related to expected throughput (I'm thinking of SHINEratio in particular), which make allowances for the expected reduction in throughput due to the retransmission.
23-12-2016 3:53 PM - edited 23-12-2016 4:03 PM
Anyway, I was doing some work on telephone extensions so I've dropped my entire network and I'll leave it off for a few hours.
Edit: I'm interested why DLM hasn't seemed to have made any changes since the remote reset even though the line stabilised after the reset was done...
23-12-2016 4:54 PM - edited 23-12-2016 8:18 PM
Connection is back up, no profile changes so far and the router is still reporting the same old stats:
Mode: VDSL2 Annex B
G.Vector: Disable
Link Uptime: 0 day: 3 hours: 32 minutes
Line Rate: 20.063 Mbps 66.996 Mbps
Actual Net Data Rate: 19.999 Mbps 66.997 Mbps
SNR Margin: 7.2 dB 7.8 dB
Transmit Power: 7.1 dBm 13.0 dBm
Receive Power: -8.5 dBm -3.4 dBm
Actual INP: 0.0 symbols 51.0 symbols
Total Attenuation: 0.0 dB 17.1 dB
Attainable Net Data Rate: 23.124 Mbps 75.226 Mbps
Line Attenuation(dB): 5.0 21.4 32.7 N/A N/A 12.0 27.4 42.5
Signal Attenuation(dB): 5.0 20.8 32.2 N/A N/A 13.2 27.2 42.5
SNR Margin(dB): 6.9 7.2 7.2 N/A N/A 7.8 7.8 7.8
TX Power(dBm): -3.6 -21.8 6.6 N/A N/A 9.6 7.8 6.9
VDSL Counters
Downstream Upstream
Since Link time = 32 min 7 sec
FEC: 2890 81
CRC: 0 23
ES: 0 16
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 2 min 37 sec
FEC: 7 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 72 0
CRC: 0 2
ES: 0 2
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 3 hours 32 min 37 sec
FEC: 2890 81
CRC: 0 23
ES: 0 16
SES: 0 0
UAS: 29 29
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Total time = 3 hours 32 min 37 sec
FEC: 2890 81
CRC: 0 23
ES: 0 16
SES: 0 0
UAS: 29 29
LOS: 0 0
LOF: 0 0
LOM: 0 0
IP profile is still reporting as 62.04. I'll keep an eye on things and see if there are any changes over the next few weeks I suppose. I'll be collecting data from DSLStats. I've also made some improvements (Mk3 SSFP faceplate, the DSL cable and links between the modem and router with fresh and tested Cat6).
Fingers crossed!
Edit: Stats are available via https://www.mydslwebstats.co.uk/, username is aneesh99
23-12-2016 9:23 PM
I'm interested in the sync now you've released the cap.
I've no access to our internal systems this weekend, however, if you private message your landline phone number I'll run the test via our suppliers and post the results.
23-12-2016 9:53 PM
23-12-2016 10:33 PM - edited 23-12-2016 10:45 PM
Thanks for your PM @aj007
And, another GEA test...
Downstream Speed | 64.1 Mbps | |
Fault Target Fix Time | ||
Time Stamp | 2016-12-10T22:00:00 |
Down Stream Line Rate | 60.0 Mbps | 66.9 Mbps | 66.5 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 894.7 Sec |
Start Time Stamp | 2016-12-23T21:30:12Z | 2016-12-23T21:45:12Z |
Ingress Code Violation | 2 | 0 |
Interestingly, the minimum line rate is still showing at 60 Mbps.
On a previous test before the sync capping...
Down Stream Line Rate | 66.9 Mbps | 66.9 Mbps | 66.9 Mbps |
Looking back, you advised you were hitting a throughput of 64 Mbps. I don't think the sync reported by GEA is your throughput. I've known people to achieve a throughput of their sync (on both ADSL and FTTC). When you bear in mind that your connection profile on our side can sometimes be set higher than it should be, or if you're provisioned on our dedicated WBC network the profile then has no bearing.
-Edit-
It turns out my web browser wasn't pasting the results in table format. All sorted.
