Could my speed be better?
- Could my speed be better?
Re: Could my speed be better?
30-11-2016 5:31 PM - edited 30-11-2016 5:32 PM
Test Outcome
Pass | |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 64.1 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 501.4 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Profile Name | 0.128M-67M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2016-11-17T17:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 66.9 Mbps | 66.9 Mbps | 66.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
I've retested your service and from the stats above; the circuit is in sync at 64 Mbps, the banding is set at 67 Mbps.
If the banding was restricting the sync then we would arrange an engineer visit. As it's the other way round, we wouldn't I'm afraid. Rather, as the banding isn't restricting the sync speed we can't arrange the visit
30-11-2016 5:37 PM - edited 30-11-2016 5:39 PM
How is my sync on my router 66.997 Mbps when your test is showing 64.1? 😕 I mean, the linestats would support the line being banded, since it's literally generating no errors at all.
As I asked before though, how come my line was reset before the work was completed, and not afterwards?
30-11-2016 5:45 PM
From your router stats your router is showing a downstream line rate of 66.9 Mbps which is also what our stats are showing.
As the sync itself is within the estimated speed and not being restricted by the banding, it's something we can't arrange an engineer for
As for the line not appearing to be reset following the resolution of the fault, I can see that your fault was fixed remotely by our suppliers capacity management team as the issue was overutilisation across the VLANs. An engineer wasn't arranged.
30-11-2016 6:07 PM
@Anoush The OP's router is reporting a downstream line rate of 66.9 Mbps - surely that is the sync speed so it is being restricted by the banding. Can you explain what the 64.1 Mbps in your test is? How can the OP have a line rate higher than the sync speed? That doesn't make much sense. I think the speed could be better if the banding was removed.
30-11-2016 6:24 PM
Yeah it seems a bit weird. My router is reporting the sync 66.9, GEA is saying the profile band is 67. My line never improved and the interleaving never backed off after the work was done. I'm really not seeing how this line isn't banded?
30-11-2016 6:34 PM
The line rate is 66.9, the sync is 64.1 Mbps. I'm not sure why DLM is not removing the banding of 67 to be honest but as the banding isn't restricting the speed we can't send out an engineer to reset the line because it's likely not to change anything.
Interleaving is also turned off. As for the discrepancy between the line rate and sync I'll look into it with my faults colleague tomorrow and will get back to you.
30-11-2016 6:42 PM - edited 30-11-2016 6:42 PM
On the ZyXEL VGM 8324, the actual line rate is the sync speed, so I'm still failing to see how the profile isn't banded. As I said before my line didn't improve at all after the problem was rectified on the 30th, the only improvement was that the mass CRC errors and error seconds cleared up.
*Sorry didn't mean interleaving, I meant re-transmission.
30-11-2016 7:34 PM
This is the worst nonsense I've heard so far in this thread. "Line rate" and "sync speed" are usually used as different ways to refer to exactly the same value, the proper technical term for which is "Actual Net Data Rate". It can't be two different values at the same time.
01-12-2016 11:06 AM
@ejs I agree with you, so far Anoush has not explained what the 64.1Mbps value is but it certainly isn't the sync speed!
01-12-2016 6:20 PM
I hadn't had a chance to look into it today and I'm on annual leave for the rest of the week.
I'll pick this back up on Monday.
Sorry for any inconvenience caused.
01-12-2016 6:50 PM
No worries, enjoy the downtime!
06-12-2016 8:07 PM - edited 06-12-2016 8:07 PM
Thanks @aj007 and many apologies for not picking this back up yesterday.
I seemed to have missed it off my To Do list I'll definitely get back to you tomorrow with clarification.
07-12-2016 10:58 AM
Thanks for your patience.
Regarding the GEA service test detail, the line rate is the sync over time, and sync shows this rounded up. If the banding was restricting the speed then the circuit would sync at the top end of the banding i.e. 67 Mbps.
I hope this helps clarify things
07-12-2016 2:51 PM
That does not help "clarify" things at all.
Have you considered the possibility that the GEA Test Result is showing an incorrect value for some unknown reason?
How do you explain that the minimum, average and maximum downstream line rate values from the test results are all 66.9? Clearly the line rate / sync speed being anything other than 66.9 would be inconsistent with those figures.
How do you explain the 66,997k sync speed / line rate reported by the modem?
The circuit is in sync at the top end of the banding, and the GEA Test Result is displaying an incorrect speed of 64.1.
07-12-2016 3:58 PM
