Continual intermittent dropped packets
- Re: Continual intermittent dropped packets
02-12-2016 10:41 AM
@ Malcky actually simple turn off everything for a night/couple of nights if intermittent and see if it clears it up, if it doesn't then more likely a connection issue unless you live next door to one of those cover their house in xmas lights crazies. If it does clear up, turn on one electrical item each night and find the culprit, it just takes time.
So tree lights, first thing to turn off at this time of year
02-12-2016 10:50 AM
@Malcky wrote:
Are you saying that other plugged in devices around the house can affect an internet connection? or at least the packet loss/errors a line gets?
If so, that is like a needle in a haystack trying to pinpoint what appliance could be causing hassle.
Yes, that is exactly true!
That is why when you do diagnostics Plusnet will always want to try to get you to put your modem in the master socket and connect your PC via a LAN cable. If your modem is a long way from your master socket, then buying expensive shielded cable can reduce interference significantly, I've seen line sync go from 55 to 75mb by using expensive cables to stop in house noise.
The amount of interference and noise in a house is quite large, especially on wifi interference (put your modem near a microwave and turn it on and see what the 2.4ghz microwaves do to your 2.4ghz wifi!)
https://support.zen.co.uk/kb/knowledgebase/broadband-understanding-rein-and-shine is an interesting read if you are interested more in it (esp. the flashing Christmas tree lights bit as we are getting near there!!)
MS
02-12-2016 11:08 AM - edited 02-12-2016 11:11 AM
Wow....thanks for the link Mr Silver, the youtube video on that link showing a AM radio tuned to 612Khz was an eye opener to say the least.....shame I don't have a radio, but might get one just for the fun of doing that test around my house.
My modem is only a foot away from the master socket and then its cat6 cable around my room to the Apple router. Its not shielded cable though.
02-12-2016 4:11 PM
@bobpullen The reason i posted in this thread about my slow peak hours speeds is because its linked to the recent packet loss issues, the slow down started when the packet loss reappeared and cannot be down to exchange congestion as a neighbour 3 doors away who is a Plusnet customer does not get the slow downs.
Last night we tested both of our connections, im on the southbank gateway and he is on the colindale gateway(despite the gateways supposedly being Geographic), he has no slow down and no packet loss while i have no packet loss(at the minute) yet slow downs, if i drop session's i cannot get a different gateway yet my neighbour does, he managed to drop sessions and get on the southbank gateway and instantly lost 30% of throughput, another drop session saw him back on the colindale gateway and his throughput returned to normal.
02-12-2016 4:28 PM
There's nothing to say you're not connecting via different SVLANs. Your neighbour having zero issues does not unfortunately rule out exchange contention.
It all depends on which of our networks you're both provisioned on, how your IP address is being assigned, what account type you have etc, what temporary routing we might have in place. It's not necessarily geographic for everybody.
He has no slow down and no packet loss while i have no packet loss(at the minute) yet slow downs, if i drop session's i cannot get a different gateway yet my neighbour does, he managed to drop sessions and get on the southbank gateway and instantly lost 30% of throughput, another drop session saw him back on the colindale gateway and his throughput returned to normal.
I'm not refuting there may be a problem somewhere, but I don't think it's best suited to this thread. The symptoms are dissimilar enough for me to think the two problems (or at least their causes) are unrelated.
02-12-2016 8:35 PM
|------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|------|------|------|------|------| | router.asus.com - 1 | 305 | 303 | 2 | 10 | 97 | 4 | | No response from host - 100 | 63 | 0 | 0 | 0 | 0 | 0 | | 137.hiper04.sheff.dial.plus.net.uk - 99 | 63 | 1 | 0 | 24 | 24 | 24 | | be3-3104.psb-ir01.plus.net - 1 | 305 | 303 | 8 | 27 | 313 | 9 | | core1-BE1.southbank.ukcore.bt.net - 1 | 300 | 297 | 8 | 27 | 309 | 9 | | host213-121-193-203.ukcore.bt.net - 1 | 301 | 298 | 8 | 26 | 312 | 13 | | t2c3-et-7-3-0-0.uk-lon1.eu.bt.net - 1 | 300 | 297 | 7 | 26 | 309 | 10 | | No response from host - 100 | 63 | 0 | 0 | 0 | 0 | 0 | | ae5.dar02.lon02.networklayer.com - 1 | 300 | 297 | 0 | 28 | 311 | 12 | | po2.fcr01a.lon02.networklayer.com - 1 | 300 | 297 | 10 | 28 | 309 | 13 | | speedtest.lon02.softlayer.com - 1 | 304 | 302 | 8 | 30 | 389 | 10 | |________________________________________________|______|______|______|______|______|______| WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
Problems have returned again the last couple of nights. this is to a server in london.
03-12-2016 8:42 PM
What a surprise, Twitch is buffering again tonight thanks to packet loss. Why can't this problem get sorted?
05-12-2016 1:09 PM
@kendo79 wrote:
|------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|------|------|------|------|------| | router.asus.com - 1 | 305 | 303 | 2 | 10 | 97 | 4 | | No response from host - 100 | 63 | 0 | 0 | 0 | 0 | 0 | | 137.hiper04.sheff.dial.plus.net.uk - 99 | 63 | 1 | 0 | 24 | 24 | 24 | | be3-3104.psb-ir01.plus.net - 1 | 305 | 303 | 8 | 27 | 313 | 9 | | core1-BE1.southbank.ukcore.bt.net - 1 | 300 | 297 | 8 | 27 | 309 | 9 | | host213-121-193-203.ukcore.bt.net - 1 | 301 | 298 | 8 | 26 | 312 | 13 | | t2c3-et-7-3-0-0.uk-lon1.eu.bt.net - 1 | 300 | 297 | 7 | 26 | 309 | 10 | | No response from host - 100 | 63 | 0 | 0 | 0 | 0 | 0 | | ae5.dar02.lon02.networklayer.com - 1 | 300 | 297 | 0 | 28 | 311 | 12 | | po2.fcr01a.lon02.networklayer.com - 1 | 300 | 297 | 10 | 28 | 309 | 13 | | speedtest.lon02.softlayer.com - 1 | 304 | 302 | 8 | 30 | 389 | 10 | |________________________________________________|______|______|______|______|______|______| WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud ProviderProblems have returned again the last couple of nights. this is to a server in london.
The second, third and eighth hops are expected behaviour. The remaining 1% loss that's end to end starts at your router suggesting an issue closer to home. This trace isn't really indicative of a broadband network problem
Are you still experiencing problems, and if you are do you have any diagnostics/monitoring you can share that shows the packet loss?
05-12-2016 4:01 PM
Yes I noticed the local problem after I posted this, I had a dodgy cable that was causing the issue,fixed now.
05-12-2016 8:23 PM - edited 06-12-2016 10:54 AM
If a fix has been tried for my connection it didn't help any, tonight 5th dec on psb-bng02 my live graph http://www.thinkbroadband.com/ping/share-large/8dec7cf519beda3b43f06c9508b6ab21.png, started at 7pm
edit still exactly same at 10.50am 6th dec
06-12-2016 3:59 PM
@Gus, we've kicked you over to Colindale which looks to have helped. We're investigating a low-level packet loss issue at Southbank (ref: 96302) that looks to have started yesterday tea-time.
06-12-2016 7:29 PM
06-12-2016 7:40 PM
@bobpullen had a power outage earlier so can add psb-bng01 to that ticket, back to the old school gateway hopping
06-12-2016 9:13 PM
So I'm at the point now that my problems started at the same time as most others (late October), but I've seen no real improvements. The packet loss I was experiencing has reduced, but at the expense of ping times and this nice blue graph.
It's been about six weeks since I first logged a fault and it doesn't seem to be going anywhere.
06-12-2016 9:35 PM
That blue graph doesn't look synonymous with any of the issues we've seen to date. I think something else is happening there. It looks to me like you're saturating your Internet connection.
If I trace to your IP, all the increased latency is at the final hop (your router).
