Continual intermittent dropped packets
- Re: Continual intermittent dropped packets
20-11-2016 10:40 PM
20-11-2016 11:23 PM
The last big thread on packet loss was 86 pages and 1279 posts long and covered a couple of months. At that time I had packet loss typically hitting 40-60% and sometimes spiking higher. I have had packet loss this week though small, it is there, this time it is intermittent. I currently have none at all but will it last... I'm not too bothered, as in just over a week I am away from this shower. I fully expect that most if not all of my current net problems will vanish when my migration completes.
21-11-2016 12:06 AM - edited 21-11-2016 12:07 AM
Well, good to know that this is a common occurrence. Glad I only have to deal with it for this year of university.
PlusNet going to be going on to my blacklist of ISPs never to go with. I guess it extends to BT as the server is at ukcore.bt.net. I considered the service from Virgin where I'd get a day with literally no internet for a few hours a couple times a year "bad". But they were always transparent with their issues and resolved them quickly so in hindsight that was me being unrealistic. Issues happen, but the lack of communication and the length of the problem (this is my 4th day (thurs-sun) with the issue) is something that I would expect from a first problem of a startup company, not from a branch company of BT. On top of the fact that this apparently happened less than half a year ago (and has happened to a more severe extent) is just too much. My trust in the company has been shattered, only been using their service for 2 months.
Also, some advice PlusNet. Make an update post about the issue, I have a sneaking feeling the disappearance of CSOs from the forums is likely due to them being swamped with phone calls about the issue. Making a post about it will reduce the number of those calls, saving a lot more time than it takes to make the post. Going into silence mode unless someone calls you is a really bad way to deal with a problem.
21-11-2016 12:34 AM
21-11-2016 12:44 AM
Wait until midnight, they said.
Well, midnight's come and gone, and here we are.
21-11-2016 2:31 AM
6 and a half hours after my guild's raid am I finally not getting any packet loss. I'm genuinely wondering if service was this bad before BT bought PN.
21-11-2016 9:21 AM
21-11-2016 9:22 AM
which is down to the amount of users/bandwidth used at the time
21-11-2016 10:11 AM
21-11-2016 10:23 AM
Last time I saw a network capacity issue was from virgin when they went mad doubling everyone's speeds. It caused a lot of throttling, but no packet loss. Lasted 13 months I believe before things stabilized.
21-11-2016 10:28 AM
well mine is worse at peak times, whats everyone else's exp?
21-11-2016 10:57 AM - edited 21-11-2016 11:01 AM
Just to add, I've been having these issues for many months and bought a new TP-Link Archer VR200 router two weeks ago in the hope it would fix them (I had tried asking Plusnet to send me a new HH to replace my Technicolor but they weren't having any of it whilst I was out of contract - brilliant customer service hey?). Anyway the new router, whilst providing much better wifi coverage in the house has not actually fixed the ping and lag spike issues everyone else here has been subjected to. It's infuriating and only occurs to me consistently in the evening (usually 10pm-midnight ish when playing FIFA / Rocket League / BF4).
Thankfully the router was a second-hand bargain so I can sell on to recoup my losses, but it's still really frustrating that the issue is clearly with Plusnet and they won't do anything.
BTW which websites are people using for ping tests, etc? I haven't done one yet and would quite like a visualisation to show the g/f so she doesn't think I'm completely mental getting so worked up over this
21-11-2016 10:58 AM
I joined Plusnet back in September, unfortunately did not hear about any of these issues. Very quickly, my perfect fibre connection that both Sky and Talk Talk had provided without issuestarted showing severe packet loss and random disconnections. I then found out I would be moving in a few weeks, so decided to see if a new connection at the new property would make things better.
Boy was I wrong! Packet loss much higher, online gaming and streaming during peak hours is almost impossible. A 40 minute show requires about 6-8 re-connections. I will raise a ticket when my 10 day line testing period is over, and if this is not resolved completely within 4 weeks I will be beginning arbitration to switch provider without cancellation charges. This is not acceptable.
21-11-2016 11:22 AM - edited 21-11-2016 2:14 PM
You can use either sites or software for ping tests. I'll outline some for you
1. Doing traceroutes via the command prompt (such as tracert google.com)
2. Using Pingtest.net
3. Setting up a thinkbroadband ping monitor (www.thinkbroadband.com/ping)
4. Using software such as WinMTR or PingPlotter (I personally use PingPlotter, although the free version only shows you 10 minutes of data).
Hope those help you.
Have a good day
21-11-2016 11:23 AM
Many thanks James, I'll give those a try later tonight.
