Content Filtering
tkapoutsis
Content Filtering
Hi All,
My Content filter is active for the standard type sites however, I can still get to them.
This is active due to tech savvy children but although active is not working.
Any ideas short of calling Plusnet?
Theo
4 REPLIES 4
Fixes: 1,600
Re: Content Filtering
Hi Theo,
Have you updated the DNS in your router settings to the following?
Primary DNS: 213.120.234.42
Secondary DNS: 213.120.234.38
Anoush
Fixes: 1,483
also if you have a static ip address it doesn't work at all.
tkapoutsis
Thanks Anoush,
I do utilise an internal DNS server and configured my Draytek router to point at that first then Google as a second.
Swapped out Google DNS address and presto, working once again.
For reference for all, I also have an external static IP address and the above works but you will need to change any internal static IP address DNS setting and any Router / Server DHCP setting to reflect 213.120.234.42 / 38 as a DNS route.
Thanks you Smiley
Theo
Fixes: 1,600
Great success Thumbs_Up
