Constantly losing my connection
- Constantly losing my connection
16-11-2016 3:34 PM
Everything was fine up till a couple of weeks ago - since then I'm constantly getting disconnected - both Wifi and Ethernet devices - the Router loses it's internet connection for a minute or two before sometimes recovering- but sometimes hangs until a power-off and on.
Is there a way to access the Visual Radius graph to see if the disconnects are being registered at Plusnet end?
Re: Constantly losing my connection
17-11-2016 11:42 AM
Sorry that you're having disconnection problems.
Looking at the connection logs, there are a few showing but not a large amount:
I've also tested the line directly and we're not seeing disconnections through that method either.
When you lose connection do you happen to notice the lights on the modem/router and see if they change?
