Constant failing of connection
cjon
Have had BT Infinity for a couple of years, been BT ciustomer for 30 odd years, changed to Plusnet Fibre & my connection drops out about 5 - qo times a day, this never happened with BT. The router is in the exact sme place? Has anyone got any ideas, nothing has changed no new electrical equipent in the house, no xmas tre lights near.
Fixes: 16
Re: Constant failing of connection
Are you using a Plusnet router? If so, which model?
Starmans
Affecting all devices or just wireless ones?
cjon
Router is I assume is the latest model just sent me in December, it turns to flashing orange, sometimes constant orange
Fixes: 55
Hi cjon,
Here's a view of disconections over the past 7 days if that helps:
<img src="http://community.plus.net/visualradius/generated/image14519128181097.png"/>
diagnostics don't show an obvious reason for this so I'd recommend trying another router as the next step and reporting a fault if you see no difference: http://faults.plus.net
Adam
 Adam Walker
