Constant connection dropouts
downlands2
I see I am not the only one with this problem. For the last 2/3 weeks we have had constant problems with the connection dropping - I have resorted to the forum now after three dropped connections in less than ten minutes. Can someone please check what is happening?
1 REPLY
Fixes: 229
Re: Constant connection dropouts
Sorry to hear you're having issues.
Our tests are showing a potential issue so we'd recommend raising a fault here
 Matthew Wheeler
