Constant blocking of Origin packets.
- Constant blocking of Origin packets.
28-11-2018 4:57 PM
Every second when downloading Battlefield 1 the router reports back blocking packets, I am also supposed to get 4mb/s but getting around 1.5mb/s instead, could that be the issue?
Re: Constant blocking of Origin packets.
28-11-2018 9:05 PM - edited 28-11-2018 9:06 PM
Hi @2Characters,
I'm sorry to hear that your router is reporting blocked packets when you are trying to download Battlefield.
I've tested your line but the test hasn't picked up any problems from here and indicates that your line is currently syncing at 35mbps, which is within the estimates:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 35.0 Mbps | ||||
Upstream Speed | 10.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 754.5 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2018-11-15T21:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 34.9 Mbps | 34.9 Mbps | 34.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 712.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-11-28T20:31:10.880+00:00 | 2018-11-28T20:46:10.880+00:00 |
Ingress Code Violation | 0 | 2 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 2 | 1 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Is the device that you're trying to download this game on connected via WiFi or is it on a wired connection? Do you experience connection problems on any other devices?
28-11-2018 9:39 PM
I use a powerline adapter so wired connection, but this happened a week or two ago where it said I was getting the normal speeds but not actually getting it however after a few days it returns to normal. My guess is because my connection kept dropping out today and yesterday the line is limiting the speeds for some time so I'll see what happens.
29-11-2018 1:29 PM
Ok @2Characters, thanks for confirming.
If the issue keeps occurring I'd advise connection the device directly to the router with an Ethernet cable just to rule out the Powerline Adapters causing an issue.
Might also be worth connecting the router to the test socket.
