Constant blocking of Origin packets.
2Characters
Every second when downloading Battlefield 1 the router reports back blocking packets, I am also supposed to get 4mb/s but getting around 1.5mb/s instead, could that be the issue?
3 REPLIES 3
EmilyD
Fixes: 117
Re: Constant blocking of Origin packets.
Hi @2Characters,
I'm sorry to hear that your router is reporting blocked packets when you are trying to download Battlefield.
I've tested your line but the test hasn't picked up any problems from here and indicates that your line is currently syncing at 35mbps, which is within the estimates:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 35.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 754.5
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-11-15T21:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 34.9 Mbps 34.9 Mbps 34.9 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 712.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-11-28T20:31:10.880+00:00 2018-11-28T20:46:10.880+00:00
Ingress Code Violation 0 2
Egress Code Violation 0 0
Errored Seconds 2 1
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Is the device that you're trying to download this game on connected via WiFi or is it on a wired connection? Do you experience connection problems on any other devices?
 Emily D
2Characters
I use a powerline adapter so wired connection, but this happened a week or two ago where it said I was getting the normal speeds but not actually getting it however after a few days it returns to normal. My guess is because my connection kept dropping out today and yesterday the line is limiting the speeds for some time so I'll see what happens.
LaurenB
Fixes: 131
Ok @2Characters, thanks for confirming.
If the issue keeps occurring I'd advise connection the device directly to the router with an Ethernet cable just to rule out the Powerline Adapters causing an issue.
Might also be worth connecting the router to the test socket.
 Lauren Barry
