Constant Packet Loss On UDP Upload
- Re: Constant Packet Loss On UDP Upload
01-10-2020 2:15 PM - edited 01-10-2020 2:22 PM
EDIT: Forgot to mention my line syncs around 40/7 and I have QOS in place capping the connection at 39/6 using OpenWRT to fix buffer bloat. All other devices that connect to the net are switched off so only the PC is connected and as you can see I'm using low bandwidth limits for the tests so the router isn't loaded.
I've been monitoring this for about a year now since I first noticed it. Since about 2015 (was on BT Infinity back then) to present-day online gaming has felt really inconsistent like I'm always at a disadvantage due to some kind of delay/being out of sync with the server. It feels like packet loss but games always report 0% packet loss in their monitoring tools.
About a year ago though I did some UDP tests and found a constant small percentage of packet loss on the UDP upload with spikes up to 12+%. I get small pockets of time where I can run tests for a couple of minutes with 0% loss but other than that it's pretty much constant regardless of the time of day.
Here's an iperf3 showing various amounts of UDP packet loss at different upload speed.
And here's the results of a continuous UDP speed test.
Here's a couple of local runs of iperf3 showing it's not local hardware or software problem.
I'm currently on the G.Inp trials but that's only been for about 6 months. I noticed this packet loss about a year ago and I'm certain its been there for years before then even when I was with BT Infinity but never noticed it. Any help appreciated.
Cheers!
05-10-2020 3:25 PM
A nudge for Plusnet staff to look at this
05-10-2020 3:49 PM
Hello @FrazUK,
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
Thanks.
20-10-2020 4:15 PM - edited 20-10-2020 4:16 PM
I've seen that having a static IP assigned to their connection has helped people with UDP packet loss in the past. Could this be helpful to me? I was just looking on my account page and cant configure a static IP even though I have been able to in the past. I have the message
If you are an existing customer
Unfortunately, this feature is not available with your current account. To raise any queries and to upgrade your account, please use the Contact Us tool here at the Portal
If you have recently joined PlusNet
It may take up to 30 minutes until you can access this feature of your account. Please try again later. Go back
23-10-2020 5:43 PM - edited 23-10-2020 5:53 PM
Looks like I now have a static IP, can someone confirm this as I've had no notification of one being applied? my host is now reported as myusername.plus.com and after a couple of router reboots, I've kept the same IP. It hasn't fixed the upload loss though. What should UDP bandwidth be like? Is it lower than your actual connection speed or should it be the same? I can see the higher the UDP bandwidth usage the more sustained packet loss I get. At just 0.5Mbs I'm getting spikes up to almost 10% loss. For example, playing CS:GO network usage for csgo.exe is hitting 0.6Mbs so surely this is causing packet loss too even if the game isn't reporting it (the game reports average over time too, so it might always still show 0% even though I am getting short spikes of packet loss). I don't want to report a fault just yet, id like some insight on this problem first. Im pasting some iperf3 logs below. Is this expected/normal? Why wouldn't games report packet loss even though I'm obviously getting it on the upload? Could it be routing? I know for a fact a BT engineer will do nothing about this, I've been having problems with gaming for years and had many BT engineers out but it was never fixed.
EDIT: I also have the pro addon so I'm guessing my UDP traffic for gaming should be prioritized.
EDIT 2: I have tested connected to the test socket, 2 modem/router setups, different network drivers and multiple rj11 and ethernet cables.
C:\Users\test\Desktop\iperf-3.1.3-win64>iperf3 -c ping.online.net -u -i 1 -b 0.5M
Connecting to host ping.online.net, port 5201
[ 4] local 192.168.1.69 port 49644 connected to 62.210.18.40 port 5201
[ ID] Interval Transfer Bandwidth Total Datagrams
[ 4] 0.00-1.00 sec 120 KBytes 981 Kbits/sec 15
[ 4] 1.00-2.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 2.00-3.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 3.00-4.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 4.00-5.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 5.00-6.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 6.00-7.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 7.00-8.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 8.00-9.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 9.00-10.00 sec 104 KBytes 851 Kbits/sec 13
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[ 4] 0.00-10.00 sec 1.04 MBytes 871 Kbits/sec 2.553 ms 8/133 (6%)
[ 4] Sent 133 datagramsiperf Done.
[ 4] local 192.168.1.69 port 51568 connected to 62.210.18.40 port 5201
[ 4] 0.00-1.00 sec 112 KBytes 917 Kbits/sec 14
[ 4] 1.00-2.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 3.00-4.41 sec 8.00 KBytes 46.4 Kbits/sec 1
[ 4] 4.41-5.00 sec 160 KBytes 2.23 Mbits/sec 20
[ 4] 0.00-10.00 sec 1008 KBytes 826 Kbits/sec 2.685 ms 12/126 (9.5%)
[ 4] Sent 126 datagramsiperf Done.
[ 4] local 192.168.1.69 port 56073 connected to 62.210.18.40 port 5201
[ 4] 2.00-3.00 sec 112 KBytes 917 Kbits/sec 14
[ 4] 6.00-7.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 9.00-10.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 0.00-10.00 sec 1.05 MBytes 885 Kbits/sec 2.679 ms 0/134 (0%)
[ 4] Sent 134 datagramsiperf Done.
[ 4] local 192.168.1.69 port 60362 connected to 62.210.18.40 port 5201
[ 4] 0.00-1.00 sec 120 KBytes 982 Kbits/sec 15
[ 4] 1.00-2.00 sec 96.0 KBytes 787 Kbits/sec 12
[ 4] 3.00-4.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 6.00-7.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 7.00-8.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 8.00-9.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 9.00-10.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.03 MBytes 865 Kbits/sec 2.568 ms 11/131 (8.4%)
[ 4] Sent 131 datagramsiperf Done.
[ 4] local 192.168.1.69 port 54164 connected to 62.210.18.40 port 5201
[ 4] 1.00-2.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 2.00-3.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 4.00-5.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 5.00-6.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.05 MBytes 878 Kbits/sec 2.610 ms 7/133 (5.3%)
[ 4] local 192.168.1.69 port 63431 connected to 62.210.18.40 port 5201
[ 4] 1.00-2.00 sec 96.0 KBytes 788 Kbits/sec 12
[ 4] 0.00-10.00 sec 1.05 MBytes 878 Kbits/sec 2.978 ms 13/133 (9.8%)
[ 4] local 192.168.1.69 port 60508 connected to 62.210.18.40 port 5201
[ 4] 2.00-3.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 3.00-4.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 4.00-5.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 6.00-7.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 7.00-8.00 sec 104 KBytes 852 Kbits/sec 13
[ 4] 9.00-10.00 sec 104 KBytes 853 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.03 MBytes 865 Kbits/sec 2.911 ms 0/131 (0%)
[ 4] local 192.168.1.69 port 65504 connected to 62.210.18.40 port 5201
[ 4] 3.00-4.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.03 MBytes 865 Kbits/sec 2.745 ms 0/132 (0%)
[ 4] Sent 132 datagramsiperf Done.
[ 4] local 192.168.1.69 port 53124 connected to 62.210.18.40 port 5201
[ 4] 1.00-2.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 4.00-5.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 7.00-8.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.02 MBytes 858 Kbits/sec 2.581 ms 0/131 (0%)
[ 4] local 192.168.1.69 port 61700 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.03 MBytes 865 Kbits/sec 2.778 ms 0/131 (0%)
[ 4] local 192.168.1.69 port 65043 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.04 MBytes 872 Kbits/sec 2.739 ms 0/133 (0%)
[ 4] local 192.168.1.69 port 54522 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.05 MBytes 878 Kbits/sec 2.778 ms 7/133 (5.3%)
[ 4] local 192.168.1.69 port 57386 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.05 MBytes 878 Kbits/sec 2.610 ms 2/133 (1.5%)
[ 4] local 192.168.1.69 port 52446 connected to 62.210.18.40 port 5201
[ 4] 2.00-3.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 5.00-6.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 8.00-9.00 sec 112 KBytes 916 Kbits/sec 14
[ 4] 0.00-10.00 sec 1.04 MBytes 872 Kbits/sec 2.961 ms 0/133 (0%)
[ 4] local 192.168.1.69 port 55734 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.05 MBytes 878 Kbits/sec 2.895 ms 0/133 (0%)
[ 4] local 192.168.1.69 port 64915 connected to 62.210.18.40 port 5201
[ 4] 0.00-10.00 sec 1.05 MBytes 885 Kbits/sec 3.019 ms 8/135 (5.9%)
[ 4] Sent 135 datagramsiperf Done.
[ 4] local 192.168.1.69 port 62545 connected to 62.210.18.40 port 5201
[ 4] 5.00-6.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 6.00-7.00 sec 96.0 KBytes 788 Kbits/sec 12
[ 4] 8.00-9.00 sec 104 KBytes 851 Kbits/sec 13
[ 4] 0.00-10.00 sec 1.02 MBytes 859 Kbits/sec 2.770 ms 4/131 (3.1%)
[ 4] local 192.168.1.69 port 61031 connected to 62.210.18.40 port 5201
[ 4] 3.00-4.00 sec 96.0 KBytes 788 Kbits/sec 12
[ 4] 8.00-9.00 sec 8.00 KBytes 65.3 Kbits/sec 1
[ 4] 9.00-10.00 sec 168 KBytes 1.38 Mbits/sec 21
[ 4] 0.00-10.00 sec 1016 KBytes 832 Kbits/sec 6.395 ms 11/126 (8.7%)
23-10-2020 6:57 PM
I'm also having the same issue with UDP upload loss
Had 3 engineers out recently, twice for voice fault and one for bridge tap.
Question #206150184 for internal plusnet reference.
My connection is 70Mb/20Mb
Running 10 Streams for 3 second at 1Mb Bandwidth - upto 30% packet loss.
iperf3 -c (my digital ocean server) -p 5004 -t 3 -P 10 -V -b 1M -u
Test Complete. Summary Results:
[ 4] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 22.336 ms 0/36 (0%)
[ 4] Sent 36 datagrams
[ 6] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 22.457 ms 0/36 (0%)
[ 6] Sent 36 datagrams
[ 8] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 21.948 ms 1/36 (2.8%)
[ 8] Sent 36 datagrams
[ 10] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 12.572 ms 8/35 (23%)
[ 10] Sent 35 datagrams
[ 12] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 7.198 ms 10/35 (29%)
[ 12] Sent 35 datagrams
[ 14] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 3.662 ms 11/35 (31%)
[ 14] Sent 35 datagrams
[ 16] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 3.695 ms 11/35 (31%)
[ 16] Sent 35 datagrams
[ 18] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 3.770 ms 11/35 (31%)
[ 18] Sent 35 datagrams
[ 20] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 3.826 ms 11/35 (31%)
[ 20] Sent 35 datagrams
[ 22] 0.00-3.00 sec 368 KBytes 1.00 Mbits/sec 3.864 ms 11/35 (31%)
[ 22] Sent 35 datagrams
[SUM] 0.00-3.00 sec 3.59 MBytes 10.0 Mbits/sec 10.533 ms 74/353 (21%)
CPU Utilization: local/sender 1.5% (0.2%u/1.4%s), remote/receiver 0.1% (0.0%u/0.0%s)
5 Streams at 2M Bandwith
iperf3 -c. (my digital ocean server) -t 3 -P 5 -V -b 2M -u
[ 4] 0.00-3.00 sec 720 KBytes 1.96 Mbits/sec 21.903 ms 5/65 (7.7%)
[ 4] Sent 65 datagrams
[ 6] 0.00-3.00 sec 720 KBytes 1.96 Mbits/sec 21.959 ms 5/65 (7.7%)
[ 6] Sent 65 datagrams
[ 8] 0.00-3.00 sec 720 KBytes 1.96 Mbits/sec 19.030 ms 17/65 (26%)
[ 8] Sent 65 datagrams
[ 10] 0.00-3.00 sec 720 KBytes 1.96 Mbits/sec 16.509 ms 23/64 (36%)
[ 10] Sent 64 datagrams
[ 12] 0.00-3.00 sec 720 KBytes 1.96 Mbits/sec 16.758 ms 23/64 (36%)
[ 12] Sent 64 datagrams
[SUM] 0.00-3.00 sec 3.52 MBytes 9.82 Mbits/sec 19.232 ms 73/323 (23%)
CPU Utilization: local/sender 1.4% (0.1%u/1.2%s), remote/receiver 0.1% (0.0%u/0.0%s)
28-10-2020 2:30 PM
30-10-2020 2:22 PM
Just had a couple of days where there was little to no packet loss on my upload and gaming has felt great. I was able to do udp tests at 3Mbs up and 3Mbs down at the same time with pretty much 0 loss....some 0.00x% loss from time to time but today the packet loss is back with lower bandwidth and gaming feels like sh*te again.
on 01-11-2020 10:12 PM - last edited on 02-11-2020 7:19 PM by dvorak
@Mads, @quinnaaa has an iperf server running atm on which I've just tested UDP both upload and download. There are tons of out-of-order packets, packet loss, and a fair amount of jitter. I think this needs to be looked into properly as simply having a BT engineer come out they will just see that the download and upload speeds are fine and say there is no problem. Does a BT engineer even check the quality of UDP throughput? I've had multiple engineers out over the years and this particular problem has never been fixed and has been a constant problem since 2015 bar maybe a week or 2 out of the year where online gaming works as it should. This poor quality UDP performance makes gaming almost impossible, at least in any kind of enjoyable way and gaming is the main reason I and many others have their internet connection in the first place.
@quinnaaa explained his problems with online gaming and from what he has said he has exactly the same problems as me.
@quinnaaa wrote:
For me when gaming as you say it's the fast moving players, players teleporting when landing shots, hit detection and aim assist non existent, lack of footsteps on enemy players, shot around corners, shot first die first, dying from what seems like a single shot yet kill cam shows multiple hits on me. The games just plays like you are half a second to a second behind everyone else. I've experience that in multiple call of duty's and destiny 1&2.
Our problems are so much the same the quote above looks like I wrote it except for aim assist since I play on PC.
Here are some test results
12Mbs ---------------------------------------------------------------------------------------------------------------------------------------------
[ 4] local 192.168.1.69 port 64951 connected to [Removed] port 5004
Starting Test: protocol: UDP, 1 streams, 8192 byte blocks, omitting 0 seconds, 10 second test
[ 4] 0.00-1.00 sec 1.44 MBytes 12.0 Mbits/sec 2.576 ms 0/184 (0%)
iperf3: OUT OF ORDER - incoming packet = 335 and received packet = 336 AND SP = 4
[ 4] 1.00-2.00 sec 1.43 MBytes 12.0 Mbits/sec 2.576 ms 1/183 (0.55%)
iperf3: OUT OF ORDER - incoming packet = 444 and received packet = 445 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 491 and received packet = 492 AND SP = 4
[ 4] 2.00-3.00 sec 1.34 MBytes 11.2 Mbits/sec 3.458 ms 2/171 (1.2%)
iperf3: OUT OF ORDER - incoming packet = 543 and received packet = 544 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 555 and received packet = 556 AND SP = 4
[ 4] 3.00-4.00 sec 1.52 MBytes 12.8 Mbits/sec 2.660 ms 2/195 (1%)
iperf3: OUT OF ORDER - incoming packet = 754 and received packet = 755 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 794 and received packet = 795 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 868 and received packet = 869 AND SP = 4
[ 4] 4.00-5.00 sec 1.43 MBytes 12.0 Mbits/sec 2.665 ms 3/183 (1.6%)
iperf3: OUT OF ORDER - incoming packet = 1034 and received packet = 1036 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1035 and received packet = 1036 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1062 and received packet = 1063 AND SP = 4
[ 4] 5.00-6.00 sec 1.43 MBytes 12.0 Mbits/sec 3.907 ms 3/183 (1.6%)
[ 4] 6.00-7.00 sec 1.43 MBytes 12.0 Mbits/sec 2.663 ms 0/183 (0%)
iperf3: OUT OF ORDER - incoming packet = 1370 and received packet = 1371 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1456 and received packet = 1457 AND SP = 4
[ 4] 7.00-8.00 sec 1.43 MBytes 12.0 Mbits/sec 2.650 ms 2/183 (1.1%)
iperf3: OUT OF ORDER - incoming packet = 1504 and received packet = 1506 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1505 and received packet = 1506 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1525 and received packet = 1527 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1526 and received packet = 1527 AND SP = 4
[ 4] 8.00-9.00 sec 1.44 MBytes 12.0 Mbits/sec 2.604 ms 4/184 (2.2%)
iperf3: OUT OF ORDER - incoming packet = 1673 and received packet = 1675 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1674 and received packet = 1675 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1822 and received packet = 1823 AND SP = 4
[ 4] 9.00-10.00 sec 1.41 MBytes 11.8 Mbits/sec 2.644 ms 6/183 (3.3%)
[ 4] 0.00-10.00 sec 14.3 MBytes 12.0 Mbits/sec 2.644 ms 23/1832 (1.3%)
[ 4] Sent 1832 datagrams
[SUM] 0.0-10.0 sec 20 datagrams received out-of-order
CPU Utilization: local/receiver 0.5% (0.3%u/0.2%s), remote/sender 0.1% (0.0%u/0.1%s)
Time: Sun, 01 Nov 2020 21:36:30 GMT
Connecting to host [Removed], port 5004
Reverse mode, remote host [Removed] is sending
Cookie: FrasersPC.1604266590.199991.4be7d88c
[ 4] local 192.168.1.69 port 49482 connected to [Removed] port 5004
iperf3: OUT OF ORDER - incoming packet = 3 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 4 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 5 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 6 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 7 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 8 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 9 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 10 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 11 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 12 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 13 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 14 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 15 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 16 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 17 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 18 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 19 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 20 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 21 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 22 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 23 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 24 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 25 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 26 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 27 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 28 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 29 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 30 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 31 and received packet = 800495 AND SP = 4
[ 4] 0.00-1.00 sec 240 KBytes 1.96 Mbits/sec 27272624439.973 ms 800494/800495 (1e+02%)
iperf3: OUT OF ORDER - incoming packet = 32 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 33 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 34 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 35 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 36 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 37 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 38 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 39 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 40 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 41 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 42 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 43 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 44 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 45 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 46 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 47 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 48 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 49 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 50 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 51 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 52 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 53 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 54 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 55 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 56 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 57 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 58 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 59 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 60 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 61 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 62 and received packet = 800495 AND SP = 4
[ 4] 1.00-2.00 sec 248 KBytes 2.03 Mbits/sec 3688387152.738 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 63 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 64 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 65 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 66 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 67 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 68 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 69 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 70 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 71 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 72 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 73 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 74 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 75 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 76 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 77 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 78 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 79 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 80 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 81 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 82 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 83 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 84 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 85 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 86 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 87 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 88 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 89 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 90 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 91 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 92 and received packet = 800495 AND SP = 4
[ 4] 2.00-3.00 sec 240 KBytes 1.97 Mbits/sec 532077379.377 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 93 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 94 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 95 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 96 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 97 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 98 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 99 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 100 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 101 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 102 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 103 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 104 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 105 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 106 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 107 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 108 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 109 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 110 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 111 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 112 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 113 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 114 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 115 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 116 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 117 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 118 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 119 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 120 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 121 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 122 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 123 and received packet = 800495 AND SP = 4
[ 4] 3.00-4.00 sec 248 KBytes 2.03 Mbits/sec 71958877.367 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 124 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 125 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 126 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 127 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 128 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 129 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 130 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 131 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 132 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 133 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 134 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 135 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 136 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 137 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 138 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 139 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 140 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 141 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 142 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 143 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 144 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 145 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 146 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 147 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 148 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 149 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 150 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 151 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 152 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 153 and received packet = 800495 AND SP = 4
[ 4] 4.00-5.00 sec 240 KBytes 1.97 Mbits/sec 10380606.879 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 154 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 155 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 156 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 157 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 158 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 159 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 160 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 161 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 162 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 163 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 164 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 165 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 166 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 167 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 168 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 169 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 170 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 171 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 172 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 173 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 174 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 175 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 176 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 177 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 178 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 179 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 180 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 181 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 182 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 183 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 184 and received packet = 800495 AND SP = 4
[ 4] 5.00-6.00 sec 248 KBytes 2.03 Mbits/sec 1403889.361 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 185 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 186 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 187 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 188 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 189 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 190 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 191 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 192 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 193 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 194 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 195 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 196 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 197 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 198 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 199 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 200 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 201 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 202 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 203 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 204 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 205 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 206 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 207 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 208 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 209 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 210 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 211 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 212 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 213 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 214 and received packet = 800495 AND SP = 4
[ 4] 6.00-7.00 sec 240 KBytes 1.96 Mbits/sec 202523.267 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 215 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 216 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 217 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 218 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 219 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 220 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 221 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 222 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 223 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 224 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 225 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 226 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 227 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 228 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 229 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 230 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 231 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 232 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 233 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 234 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 235 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 236 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 237 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 238 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 239 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 240 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 241 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 242 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 243 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 244 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 245 and received packet = 800495 AND SP = 4
[ 4] 7.00-8.00 sec 248 KBytes 2.03 Mbits/sec 27392.418 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 246 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 247 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 248 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 249 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 250 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 251 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 252 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 253 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 254 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 255 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 256 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 257 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 258 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 259 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 260 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 261 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 262 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 263 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 265 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 266 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 264 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 267 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 268 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 269 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 270 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 271 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 272 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 273 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 274 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 275 and received packet = 800495 AND SP = 4
[ 4] 8.00-9.00 sec 240 KBytes 1.97 Mbits/sec 3954.391 ms 0/0 (0%)
iperf3: OUT OF ORDER - incoming packet = 276 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 277 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 278 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 279 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 280 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 281 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 282 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 283 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 284 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 285 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 286 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 287 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 288 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 289 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 290 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 291 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 292 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 293 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 294 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 295 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 296 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 297 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 298 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 299 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 300 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 301 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 302 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 303 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 304 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 305 and received packet = 800495 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 306 and received packet = 800495 AND SP = 4
[ 4] 9.00-10.00 sec 224 KBytes 1.84 Mbits/sec 655.178 ms 0/0 (0%)
[ 4] 0.00-10.00 sec 2.39 MBytes 2.01 Mbits/sec 541.370 ms 800494/800495 (1e+02%)
[ 4] Sent 800495 datagrams
[SUM] 0.0-10.0 sec 304 datagrams received out-of-order
CPU Utilization: local/receiver 0.5% (0.2%u/0.3%s), remote/sender 0.1% (0.0%u/0.1%s)
1.9Mbs ---------------------------------------------------------------------------------------------------------------------------------------------
Time: Sun, 01 Nov 2020 21:37:31 GMT
Cookie: FrasersPC.1604266651.975522.2e05710d
[ 4] local 192.168.1.69 port 52705 connected to [Removed] port 5004
[ 4] 0.00-1.00 sec 240 KBytes 1.96 Mbits/sec 15.215 ms 0/30 (0%)
[ 4] 1.00-2.00 sec 224 KBytes 1.83 Mbits/sec 4.315 ms 0/28 (0%)
[ 4] 2.00-3.00 sec 232 KBytes 1.90 Mbits/sec 2.498 ms 0/29 (0%)
[ 4] 3.00-4.00 sec 232 KBytes 1.90 Mbits/sec 2.256 ms 0/29 (0%)
[ 4] 4.00-5.00 sec 232 KBytes 1.90 Mbits/sec 2.236 ms 0/29 (0%)
[ 4] 5.00-6.00 sec 232 KBytes 1.90 Mbits/sec 2.166 ms 0/29 (0%)
iperf3: OUT OF ORDER - incoming packet = 200 and received packet = 201 AND SP = 4
[ 4] 6.00-7.00 sec 232 KBytes 1.90 Mbits/sec 2.297 ms 1/29 (3.4%)
[ 4] 7.00-8.00 sec 232 KBytes 1.90 Mbits/sec 2.192 ms 0/29 (0%)
iperf3: OUT OF ORDER - incoming packet = 234 and received packet = 235 AND SP = 4
[ 4] 8.00-9.00 sec 232 KBytes 1.90 Mbits/sec 2.262 ms 1/29 (3.4%)
[ 4] 9.00-10.00 sec 232 KBytes 1.90 Mbits/sec 2.176 ms 0/29 (0%)
[ 4] 0.00-10.00 sec 2.27 MBytes 1.90 Mbits/sec 2.176 ms 2/290 (0.69%)
[ 4] Sent 290 datagrams
[SUM] 0.0-10.0 sec 2 datagrams received out-of-order
CPU Utilization: local/receiver 0.3% (0.0%u/0.3%s), remote/sender 0.1% (0.0%u/0.1%s)
Moderators Note: IP address removed,
02-11-2020 4:53 PM
I've just had customer service reply to my open ticket with the generic we've testing your line and cannot find a fault.
I've had 3 profile changes in the last 6 weeks, the Open reach engineer requested that interleaving be turned on but that looks to have been reset again and retransmission is high. Also the last engineers visit dropped the connection from 80mbps to 70Mbps download.
0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Interleaving On
0.128M-80M Downstream 5dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Can this be escalated any way within Plusnet? My contract is up for renewal today and right now I'm in two minds.
Surely there are people at Plusnet that can do a deeper dive into the issues we are seeing.
How can customer services state there is nothing wrong when they test as they cannot initiate an upload from my side.
