Connexion dropping multiple time a day
FLdn
Hi
My connexion has been dropping multiple time a day in the last week after many years without any issue
The router has been rest and does not appear to be overheating or any other abnormality
Could you please help ASAP ? I am on call all day and the dropping connexion has huge impact on my work
Many thanks
Fabienne
12 REPLIES 12
Legend
Fixes: 253
Re: Connexion dropping multiple time a day
@FLdn Welcome to the forums. In order for other community members to help you, it would be a good idea to have a look at This link and report back with as much of the requested information as possible. It would also be a good idea to do a 'Quiet Line Test' - dial 17070 and select option 2 from a landline phone - and check for any noise on the line. If there is any, report a phone fault to your supplier before reporting a broadband fault.
FLdn
Hi john
Thanks for taking the time.
we have followed your guidance with the laptop directly connected to the plusnet router via Ethernet (not wireless). it comes from the router which display red lights when dropping.
The router is also directly plugged in via adsl adapter to the faceplate. We have done the basic test using your BT WHOLESALE website and wanted to run the addition test but required the BBEU ID as using the telephone number did not run the diagnostic test and came back with a busy line response yesterday and during 4 attempts today. Hence we want to try with the BBEU ID that we can not find anywhere
The line dropped 3 time today already
Many thanks for your help
FLDN
Legend
Fixes: 253
@FLdn First, I am not Plusnet staff, just a long-time user who tries to help others, so none of this is 'mine'😉
I'm not quite sure why it will not run the advanced test if it completed the Basic test - what results did you get, if any , on that?
Your BBEUID is not one you will find anywhere unless Plusnet have run a full test for you - which I suspect from your original post they haven't had need to - but don't worry about it for the moment.
Don't take this wrong, but did you enter your full telephone number when asked - dialling code and your own number as one long string?
One final question - did you carry out the Quiet Line Test on your phone - dial 17070 and select option 2, preferably from a corded handset if possible. The line should be almost totally silent, any noise needs to be reported as a phone fault before the broadband error.
FLdn
Hi john
Many thanks very nice of you to try to help
so we got the diagnostic at the end and it all good.
we have done the phone test but using a wireless phone which is quite old we can hear some noise but difficult to know if it is interference or noise.
might worth trying to raise though. What do you think ? Our phone provider is plusnet too, shall I raise it with customer service ?
Many thanks
FLdn
We’ve run a test with the link provide de on the forum and result are that our line has no issue. Could it be the BT Fiber to copa converter station cabinet situated on the road which is overheating as w3 do not seem to experience the drop out in the evenings as the exterior temperature lowers?
What do you think ?
Legend
Fixes: 253
@FLdn If the QLT test came back clear as you say, that (nearly) rules out a phone-line problem , although if it is an intermittent issue there could stil be a problem, but one which will be difficult to prove.
Your comment re: the VDSL cabinet is enlightening - if you are on FTTC you have taken this outside my area of expertise, and from reading the 'Speed Faults' sticky on that board, it appears there is very little diagnostics available to an end-user.
If you can confirm you are on FTTC, I will ask for this topic to be be moved to the appropriate board, and hopefully someone with experience across there will pick it up.
FLdn
Hi John
i can confirm that the connections FTTC and we are using the sagemcom plus net hub one modem router
we noticed last night that actually wit( cooler temperature it is still dropping out
many thanks
Legend
Fixes: 253
OK, @FLdn . Takes it out of my zone of expertise, I shall ask for the thread to be moved to the Fibre board.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
FLdn
Many thanks @jab1
FLdn
Hi @dvorak
any followup on my issue ?
Many thanks
FLDN
Legend
Fixes: 253
@FLdn Sorry, @dvorak is a customer and mod - not a PN staffer.
You need to hope that one of the PN Help Team pick this up - unlikely at the moment - or one of the more experienced community members chimes in.
