Connectivity issues
- Connectivity issues
Connectivity issues
27-10-2016 8:17 PM - edited 27-10-2016 8:17 PM
Router is connected and the gateway is reachable but nothing works.
Keeps doing this - getting very annoying
Message 1 of 2
(529 Views)
1 REPLY 1
Re: Connectivity issues
28-10-2016 9:14 AM
Hi @SteveA by any chance have you given someone else one of your old routers that may have still had your connection details stored in it? Looking at your account, this is likely causing the problem you're experiencing as another connection is using your connection details.
