Connections timing out
- Connections timing out
08-12-2016 1:14 PM
I have Plusnet Unlimited Fibre. I mainly use a desktop PC, which is connected with an ethernet cable. For several weeks, I have been getting connections which time out. I can't connect to my work's VPN. My mobile, when connected to my wifi, sometimes reports the connection as "unstable".
I went on the Plusnet live help page, where the help guy typed that I should try another browser and change my ethernet cable. Though neither of these seemed very plausible, I did both... but they didn't help.
Thanks,
Jane
Re: Connections timing out
08-12-2016 2:54 PM
Hi Jane,
What's odd is that your connection from the exchange to the router has been up and running without fault for 36 straight days.
What VPN service is it that you use to connect to the office?
Matty
08-12-2016 4:52 PM
Hi Matty
We use "BIG-IP Edge Client".
Many thanks,
Jane
02-02-2017 3:12 PM - edited 02-02-2017 3:20 PM
Hi
I have gone from connections timing out some of the time to most of the time to all of the time. Please help! I can't work at home, and this is messing up my life. The connection is still in some sense live because the occasional e-mail gets through, but most other programs that need an internet connection are getting timed out. See attached screenshots.
Thanks,
Jane
02-02-2017 10:02 PM
I have been getting the same all this week every couple of hours the connection just drops. When it tries to reconnect it gets to PPP connecting... and then wont connect.
