Connection slow, dropping frequently, now completely dead
- Connection slow, dropping frequently, now complete...
02-12-2018 8:12 PM
For the last two weeks or so our internet connection has been intermittently dropping or getting very slow download speeds (0.5mbps, 300+ ms jitter, upload is fine though). These have been getting steadily worse, and where before restarting the router generally fixed them, the internet has now been down for the best part of an hour with restarting doing nothing.
This is happening over both wired and wireless connection, with the orange light and the broadband light both illuminated. I've replaced the cable from the wall socket (the master) to the router just in case something had happened to that, but no luck.
Any other suggestions?
Cheers
Re: Connection slow, dropping frequently, now completely dead
03-12-2018 2:24 PM
Sorry to hear you're having issues with your connection.
We've tested your line and it's showing that the password stored in your router is incorrect,
In the first instance we'd try resetting the router using the pinhole on the back.
Failing that I've included a guide below with instructions on how to do this manually.
1) Open a browser
2) Enter 192.168.1.254 into the address bar
3) On the router's home screen, select 'Settings'
4) Enter the password. This is the 'Admin Password for Hub Manager' on the removable card on the rear of the router (it can also be found on the base of the router)Within the 'Settings' menu, select the 'Broadband' tab or 'Enter your broadband username and password'
5) On the following page, you must enter the broadband username and password (There is a 'show characters option on this page if you are struggling with entering the password)
6) Click the 'Connect' button. The power light should turn blue to indicate that there is an internet connection.
Let us know how you get on
11-12-2018 9:51 PM
Thanks very much for your help - looks like it might have been a chrome autofill mishap while restarting the router! Since re-entering my details I've had a connection, but it is still dropping frequently requiring router restarts, and in the evenings the fastest speedtests I've done have resulted in only about 16mbps download speeds. Do you have any ideas on what might be causing these issues?
Cheers!
12-12-2018 1:12 PM
