Connection settings
FIXED- Subscribe to RSS Feed
- Re: Connection settings
05-11-2016 10:30 AM
Is the password used in connection settings the same one as used to login into my account on the web portal?
Fixed! Go to the fix.
05-11-2016 11:16 AM
Yes
on 05-11-2016 11:56 AM - last edited on 05-11-2016 12:35 PM by Mav
That rules that out then 😞
I've recently purchase a FritzBox 7490 and it will connect through the BT modem but not directly. The screenshot is of the settings used when I attempt to use the FritzBox for the connection. It reports "DSL is available (DSL synchronization exists with 67885/20000 kbit/s)" followed by "PPPoE error: Timeout".
The only change from the connection which works via the BT modem is the switching of the bullet from External modem or router to Connecting to a DSL line.
Any ideas?
Moderator's note by Mike (Mav): User name/email address removed from attachment in a public forum.
05-11-2016 12:33 PM - edited 05-11-2016 12:41 PM
Pretty sure you need to add a VLAN setting, you may want to do a search for the details.
Edit - Have a look at this thread. W23 seems to have got the settings.
05-11-2016 1:45 PM
That did it! Thank you.
