Connection problem
hutton79
Connection problem
I reported a fault Thursday to Plusnet we currently have no connection on fibre optic .It is an issue with my neighbours to so it is an issue elsewhere maybe at the exchange . My router internet light is flashing yellow but I still have no connection at all.The broadband light is not showing anything I’m confused as to which light should be on to have it working properly
3 REPLIES 3
Fixes: 419
Re: Connection problem
The flashing yellow light will be telling you it's failing to connect and failing. Everything else is irrelevant - you need to chase Plusnet to get the fault fixed.
hutton79
I have told them just not any movement on it being sorted I think it’s up to BT to fix it very frustrating .
SammyM
Fixes: 96
Hello @hutton79
We can see that we have updated you in regards to your fault. Please can back to us if you are experiencing any further problems.  Smiley
 Sammy M - Sheffield Team
