Connection last for about 20 seconds
- Re: Connection last for about 20 seconds
25-11-2017 6:36 PM
For the last four days, my connection only lasts about 20 seconds, then disconnects. Light goes from blue to orange with the broadband red light coming on. I have reset everything several times and logged on to the router for a manual reset several times. WAN box has all green lights. Telephone line is Ok. I raised a question regarding this on Wednesday, but other than we are running tests and will be in touch, I have heard nothing. I cannot ring the help desk as I have an irrational phobia of telephones. Any one got any ideas
Message 1 of 3
(574 Views)
2 REPLIES 2
25-11-2017 9:36 PM
I live in Golcar, Huddersfield. Since I got an email 4days ago saying my service has now been improved. It's completely the opposite and in fact, is the exact same as above! If this carries on Plusnet I'll be calling up puttting in a claim because I'm not paying for a service I'm not receiving....
Message 2 of 3
(539 Views)
26-11-2017 4:00 PM
Hi there.
I'm sorry to hear you're experiencing connection problems.
Your connection doesn't look too good:
Testing your line isn't identifying a definitive cause of that.
Have you tried plugging your router into the test socket? This would help rule out all internal wiring.
It may also be worth trying a different router if you can too.
Sorry to hear that. Your connection is also fairly intermittent.
Line tests are detecting a potential fault so I'd recommend reporting this to us at http://faults.plus.net
Message 3 of 3
(508 Views)
