Connection keeps dropping to less than 10mbps
egg1000
Yesterday and today we've found the internet service to be worse than we expect. Investigation has shown that the internet has dropped to 7mbps yesterday and 8 mbps today. Checking the line for noise, both times has shown that there is no noise on the line (although there has been in the past few weeks on and off) and after a router reboot we've connected again at over 35mbps which is what we would expect.
As the service has dropped below the guaranteed minimum on a number of occasions, by a lot, what do I do next?
5 REPLIES 5
RichardB
Champion
Fixes: 34
Re: Connection keeps dropping to less than 10mbps
HI @egg1000
How are you checking the internet speed?
A speedtest on a device connected by WiFi , a PC connected by Ethernet or checking the Line/Synch speed as reported by the router?
Internet speeds can be reduced by interfering radio signals from neighbours WiFi, Microwave Ovens, Wireless Video sensors etc.
If it is a speedtest an a device connected by WiFi, can you please check on a PC connected by Ethernet?
If the wired speedtest is slow or the router is reporting a slow line/synch speed then there is a troubleshooter at:
https://faults.plus.net
Depending on the results of the troubleshooting process,a fault will be raised with Plusnet.
Another potential issue, at Christmas, is electrical noise radiated fr the from poorly designed Christmas lights interfering with the Routers VDSL "telephone line" signal. If the routers line/synch connection speed is slow, tt could be worth checking to see if Christmas lights could be causing the problem.
Regards
Richard
egg1000
The router connection page.... it's gone again since posting. We're back here. Disconnect, reconnect at random. Screenshot 2020-12-13 at 11.03.25.png
RichardB
Champion
Fixes: 34
If this has just started happening are any Christmas decorations in use?
If not follow the faults link.
egg1000
I've logged a fault.
egg1000
Could Christmas tree light affect the wired connection to the phone line, the slow connection is between the socket and the router. There are no Christmas lights anywhere near the router. Wifi isn't enabled on the router.
