Connection keeps dropping a couple of times a day
- Connection keeps dropping a couple of times a day
14-07-2020 11:16 PM - edited 14-07-2020 11:20 PM
I've changed my mums router to a FritzBox 3490 (we were getting DNS issues with the plusnet router - even using ethernet - and also I was setting up a Fritz Mesh network)
Anyway I'm seeing that the connection drops a couple of times a day: And have the following in the logs after connecting:
The quality of the signal is being impaired by incorrect cabling. Please make sure that your line does not include any branching or multi-distributors. The branch is 35 meters long. It is impairing the transmission rate by around 16191 kbit/s.
Should I adjust the line settings to be more stable or should I request a line reset from Plusnet?
Message 1 of 2
(426 Views)
1 REPLY 1
Re: Connection keeps dropping a couple of times a day
15-07-2020 12:17 PM
Any pointers appreciated!
Message 2 of 2
(389 Views)
