Connection issues
- Connection issues
Connection issues
11-08-2019 11:58 AM
For the last 24 hours, my connection has been dropping out constantly. The hub flashes red for a few minutes, then turns back to blue for a few minutes and the process starts again. I've looked through the forums, checked the service updates but I'm not seeing any issues. I'm on Unlimited fibre extra, the hub is high up and located centrally and connected directly into the master socket using th ADSL filter box supplied. Are there any issues on the plusnet end and is anyone else having connection issues. Thanks in advance.
Re: Connection issues
11-08-2019 12:56 PM
11-08-2019 3:16 PM
This has been affecting me since Thursday, with repeated disconnects ranging from hours apart to no more than a couple of minutes. Use of my internet service has been impossible to use at all when at its worst, particularly in the evenings. I've had an open ticket bumped around various departments but no contact or explanation yet as to what's happening.
11-08-2019 6:33 PM
Thanks you both for the replies and good to see they've looked at your issue Corrn12. It looks like you've had similar issues to me although my connection has been pretty ok for the last few hours. I wished they'd check into it though.
12-08-2019 9:07 AM
Hi @Will31
I've taken a look at your connection and I can see the drop outs - there are much more than we would expect for a healthy line.
I ran a few tests, and regrettably, found no fault which would cause this to happen.
Can you run through our troubleshooting guides here .
If that doesn't help, the next thing would be to rule your internal wiring out by plugging the connection into your test socket (which is under the faceplate of your master socket) and seeing if the drops stop.
This rules out your internal wiring, face plates and extension sockets as being the cause of these drops.
How to locate the test socket and set your connection into it can be found here
If the problem still persists, please can you raise a fault here
Kind Regards,
MoR
12-08-2019 6:20 PM
12-08-2019 8:14 PM
Hiya @Will31
I can see the drops are still occurring.
Can you raise a fault following the link @MasterOfReality gave above, letting us know here on the forums when you have done so.
17-08-2019 9:17 PM
18-08-2019 9:29 PM
Hi @Will31
Thanks for coming back to us.
I've just checked your account and can see that you regained connection around 18 hours ago and that there are no external faults with your service.
How are things looking from your side?
Best wishes
Dave
13-09-2019 9:30 PM - edited 13-09-2019 9:38 PM
Over the last 48 hours the connection has been terrible, constant drop outs. 3 times in the last 10 minutes. I'm seriously considering early cancellation at this point.
edit, I still haven't received a reply from the last time i reported a fault either. I'm guessing when it's looked into it'll show no faults in the network.
14-09-2019 5:31 PM
Hi there @Will31,
Thanks for getting in touch.
I'm sorry to hear of the connection issues you have been experiencing. I can see the previous issue you raised on 17th August was responded to here earlier however we were waiting a response from you as nothing was found at the time of our response.
With regards to the connection, I can see a number of drops over the last few days. Before we raise this as a fault and in order to ensure the fault can be reported to our suppliers as current, please can you run through the troubleshooting steps here.
These steps include plugging into the test socket beneath the faceplate to see if the drops continue, and will rule out any internal wiring or the sockets themselves as being behind any interference or drops. The test socket procedure can also be found here.
If the problem still persists, please can you come back to us via this ticket and let us know here once you have done so.
Thanks - LF
14-09-2019 7:15 PM
Thanks for the reply. I have replied via the ticket.
15-09-2019 3:36 PM
Hi @Will31,
Thanks for getting back to us. I've reviewed the ticket and sent a further response now. Please let us know once you've had the chance to respond so that we can pick this back up for review as soon as possible.
