Connection issues
- Connection issues
Connection issues
14-11-2018 10:32 AM
Hi over the last few days my router has been slowing flashing red bar, maybe 2/3 times a day. And then its fine once it comes back on.
Message 1 of 2
(306 Views)
1 REPLY 1
Re: Connection issues
14-11-2018 3:03 PM
I've just been looking into this, our logs are showing up the disconnections you've mentioned on some days more than others
I've just been running diagnostics which are showing a potential issue with a "high resistance joint" being detected.
We can usually get these resolved without the need for an engineer visit so I'll get it reported now for you.
Message 2 of 2
(277 Views)
