Connection issues
deanmrd
Connection issues
Hi there
not surer if any fault with my line past 3 days I have has connections issues with my internet the issues only last for about 10 min max before the Dsl light comes back on my Openreach box I had no internal wire changes can
Dean,
Tags (2)
5 REPLIES 5
Fixes: 107
Re: Connection issues
Hi there Dean,
I've just taken a look at your account and ran some diagnostics, we're not seeing any issues or faults being flagged up.
Please give the checks here a try if you're still having problems and do keep us posted:
https://www.plus.net/help/broadband/connection-troubleshooting/
 Adam Walker
deanmrd
Hi Adam
I've had no changes to the wires in the house as you can see last night it says session closed about 02:30 I was online gaming at this point when the dsl light started flashing. Could it be a faulty openreach box?
Dean.
Fixes: 107
Hi Dean, in all honesty a fault is more likely than an issue with the modem. Please give the troubleshooting steps a try , if they don't help to resolve it I'd report a fault over at http://faults.plus.net
Adam
 Adam Walker
deanmrd
Hi Adam
I checked everything advised follow steps. It opened a support ticket, just check it say it was closed by customer only thing is I never closed it?
Dean.
Fixes: 47
Hi @deanmrd,
Thanks for getting back in touch with us. I've reviewed the situation today and raised a ticket via your account in response, which can be viewed here.
Once you've responded to the ticket, please let us know and we'll be happy to assist further.
 Alex H
