Connection intermittently awful - line check required
gjwilmoth
I'm having real problem with my fibre broadband connection.  I seem to have relatively decent speeds of 20-50mb and a ping of around 15ms but I'm constantly getting booted out of programs that require a live connection (e.g. Netflix, Microsoft NAV, Zoom) suggesting that something is dropping.
I'm 99% certain it's not the wifi as the laptops and phones i'm using have no problem connecting to the wifi during the drop outs.
I've had problems on the line before and i'd like someone to check if there are currently any problems on my line.
Tags (1)
15 REPLIES 15
ecrTech
Re: Connection intermittently awful - line check required
Hi sometime VPN can-do that on Wi-Fi, see how it goes on wired
gjwilmoth
It's worse wired.  I have Devolo magic 2 powerline and I had to stop using it because the signal would drop out so often.
Fixes: 1,483
Can you check in your router log when it happens again to see if the connection is actually dropping or not?
Something like network uptime in status, can't remember what it's exactly called in the hub one.
ecrTech
Well than you need to factory reset your equipment, because they too get infected whether its TV box or fire stick
Fixes: 1,483
No they don't, that is not the default go to solution and infected with what? More FUD. Please stop.
gjwilmoth
It says the uptime is 3 and half days.  It did reset itself during the bad weather a few days ago and I can't see anywhere to download a log.
ecrTech
Go to troubleshooting  event log
Fixes: 1,483
Can you post your router stats from  'Troubleshooting' > 'Helpdesk'
ecrTech
there is no ( Advanced Settings > Technical log ) stop confusing others
gjwilmoth
It's Troubleshooting > Event log but there are a number of choices and you can't download the log as a file, so i'll have to copy and paste page by page (it's not all on one screen)
ALL
System
WAN
USB
NTP
Boot
GUI
Wire LAN
Wifi
Port Fowarding
DHCP
Button Press
TR069
Firewall
DynDNS
Any of those I should put up? Do I need to redact any of the information for security?
Fixes: 1,483
what's under the 'Troubleshooting' > 'Helpdesk' page?
Don't post the serial number or username
gjwilmoth
1. Product name: Plusnet Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.263 Last updated 10/03/19
4. Board version: Plusnet Hub One
5. DSL uptime: 4 days, 02:39:44
6. Data rate: 19999 / 76344
7. Maximum data rate: 24561 / 91766
8. Noise margin: 8.4 / 7.1
9. Line attenuation: 11.4 / 12.6
10. Signal attenuation: 11.6 / 12.6
11. Data sent/received: 193.3 GB / 251.3 GB
12. Broadband username:
13. 2.4 GHz Wireless network/SSID: PLUSNET-HPM3
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-HPM3
18. 5 GHz Wireless connections: Disabled
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: 52
21. Firewall: Default
22. MAC Address: 3c:17:10:7e:29:d2
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
Fixes: 1,483
I'm a little jealous of those data rates.
Your connection speed is around 70mbps - so above what you are seeing. Which on wireless is possible.
Have your tried a speed test plugged directly into the router with an ethernet cable?
Your laptops aren't apple by any chance?
gjwilmoth
Not Mac, Dell XPS 17 (2020).
The frustrating thing is that I can't work out where the signal is being dropped, I think it's the fibre optic signal into the house but it could just as easily be wifi interference (sky Q)or a faulty router and I just want to rule out fibre optic before I start messing about with the wifi.
I've tried Netgear Orbi's and Devolo Magic 2 powerlines but both are unstable.
