Connection gone bad
tcp
Connection gone bad
My connection looks to have had a bad day on Saturday and hasn't recovered. Can somebody have a look at this for me please and maybe give it a little reset? The connection is working just now, but very slowly and a little hit and miss sometimes.
Thank you.
http://www.thinkbroadband.com/ping/share/c584b05dce31c97c86d5cf578168baab-27-12-2014.html
Fixes: 162
Re: Connection gone bad
Unfortunately on FTTC we don't have the tools to perform a remote reset of the line. To reset a line we need to go through the faults process and an engineer needs to do this after they've rectified a problem. I'd suggest going through https://faults.plus.net so we can take a more detailed look at what's happening and see what needs to be done.
 Chris Parr
 Plusnet Staff
tcp
Hi Chris,
I completed the troubleshooter, but the connection failed while I was doing it. Found that the Openreach modem had lost sync. Anyway the troublshooter says it has raised a ticket, and I will wait for a response.
Fixes: 162
It looks like we need to arrange an engineers visit, can you reply to the ticket with the best dates and times so we can get this booked in for you.
 Chris Parr
 Plusnet Staff
