Connection drops
mcjizja
Connection drops
I seem to be getting fairly regular connection drops again, similar but not quite as often as the upload issue a few weeks ago - which I received a firmware update for. Is it back? Or can someone see if something else is going on please?nks
Fixes: 238
Re: Connection drops
From what I can see your connection has been stable for over 9 days?
Are you connected over a wired or wireless connection?
 Matthew Wheeler
mcjizja
Wireless, but well within range. Thanks for the info, I will monitor for a pattern.
Fixes: 238
Do you have any devices that connect over a wired connection at all?
It would help to see if they have the same issue.
 Matthew Wheeler
