Connection drops every few minutes
- Connection drops every few minutes
23-07-2018 4:49 PM
Re: Connection drops every few minutes
23-07-2018 6:34 PM
Unless a Plusnet staffer comes along and says that they can see the fault at their end you are going to have to determine whether or not it's a wireless problem. Are there any lights on your router that change when you have a dropped connection?
Ideally you need to be checking by using a wired connection for a bit.
23-07-2018 7:39 PM
24-07-2018 11:01 AM
24-07-2018 11:14 AM
24-07-2018 12:37 PM
24-07-2018 1:32 PM
24-07-2018 1:36 PM
24-07-2018 1:41 PM
