Connection drops every few minutes
Jack17a
Hi, my connection seems to freeze and restore itself every few minutes. At first I thought it was just on Wi-fi so I scanned best channels and adjusted the router accordingly but it still continued. I very rarely use a lan connection as I tend to just use my iPhone mostly so I don’t really know if wired has the same problems. I was using the one hub but since then I have now fitted a netgear d7000 and still having the exact problems so am now out of ideas. When I am connected I get speeds of about 70mb and upload of about 18mb
8 REPLIES 8
Fixes: 418
Re: Connection drops every few minutes
Unless a Plusnet staffer comes along and says that they can see the fault at their end you are going to have to determine whether or not it's a wireless problem. Are there any lights on your router that change when you have a dropped connection?
Ideally you need to be checking by using a wired connection for a bit.
Jack17a
I haven’t checked the lights on the router but I will keep an eye out as soon as am home
MatthewWheeler
Fixes: 479
Sorry to hear you're having issues.
Our tests aren't showing any issues for this.
We'd need you to try a wired connection to investigate further
 Matthew Wheeler
Jack17a
Just out of interest how do you know who’s line to check as I haven’t told you what my details are
Fixes: 1,600
We can find your account from the details in your forum profile.
Jack17a
Both Wi-fi and lan have been ok so far today which is a good thing but also slightly annoying as I haven’t got to the bottom of the fault so am sure at some point the problem will be back. Gandalf thank you for your help
Jack17a
Also I have got another router (netgear d7800) coming at some point this week to replace the netgear d7000 as I am hoping to increase my Wi-fi range. So if the fault does come back am pretty certain 3 routers would rule out any faults my end
Fixes: 1,600
No problems.
Let us know if or when the problem comes back.
