Connection dropping out Plusnet Hub One
- Connection dropping out Plusnet Hub One
04-06-2021 11:03 AM
My internet has been dropping constantly over the last week. Before it disconnects the router shows the following in the log:
( 187.870000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
I read this is something to do with the router not associated with my account or something based on threads I have read with @Gandalf helping.
Let me know if there is a fix
Re: Connection dropping out Plusnet Hub One
04-06-2021 1:46 PM
Thanks for your post @Gerard_q
Could you drop me a PM with the serial number of the router you're using?
04-06-2021 2:07 PM
04-06-2021 2:14 PM
Thanks Gerard. I've enabled your router on our hardware management platform (For some reason it dropped off)
Can you factory reset the router by pushing a paperclip into the reset pin hole at the back for 20 seconds?
Let us know how it goes.
04-06-2021 2:20 PM
04-06-2021 2:27 PM
01-07-2021 5:49 PM - edited 01-07-2021 5:55 PM
I'm still having the same issue. But now seeing this when the connection drops. Happened around 5-6 times today
16:43:00, 01 Jul. (15154.860000) CWMP: session closed due to error: Could not resolve host
16:43:00, 01 Jul. (15154.840000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
I have factory reset now twice. My current firmware on the router shows one from 2019, is this the correct firmware? Thanks.
Here is the full from a newer dropout:
16:52:49, 01 Jul. (15743.990000) CWMP: session closed due to error: Could not resolve host
16:52:49, 01 Jul. (15743.970000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
16:52:49, 01 Jul. (15743.960000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
16:52:49, 01 Jul. (15743.680000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
16:52:46, 01 Jul. (15741.180000) PTM over DSL is down after 8 minutes uptime
16:52:46, 01 Jul. (15741.170000) PPPoE is down after 7 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
16:52:43, 01 Jul. (15738.510000) PPP LCP Send Termination Request [User request]
01-07-2021 6:11 PM - edited 01-07-2021 6:12 PM
Hello @Gerard_q
Thank you for reaching out again. While @Gandalf has re-added your router onto our system with the correct credentials, a separate issue has now been found. My KBD test has detected a Bridge Tap on the line which is usually caused by defects in the internal wiring / connections. Prior to raising this issue with our suppliers, we'd first kindly ask that you go through some Troubleshooting steps which can be found here
When testing, if you can, remove the face plate from your master socket, and connect your router directly into the test socket. also avoid the use of any extension cables / sockets which you might have in the property. Leave it in, and avoid resetting your router for 72 hours.
Our tests have also picked up an impairment in the local network though, so if this doesn't resolve the issues you're having, there may well also be an external fault.
Let us know how you get on, and we'll be more than happy to follow up
I'll attach my KBD test to this post so you can have a look.
01-07-2021 6:25 PM
I now have the router plugged directly into the test socket, removing the MK4 Openreach faceplate.
So I leave that in for 72 hours? We had an engineer out a few years back who replaced our internal wiring. The old cable is still running into the house from outside, although it no longer is actually connected to the socket.
Hopefully this information helps and can get this resolved asap
01-07-2021 6:46 PM
Thanks for your response @Gerard_q
Thanks for connecting your router into the test socket. Yes please, 72 hours should be fine, avoid resetting your router so that we'll be able to attribute any disconnections on the line to network issues, rather than you resetting the router.
Bit strange how the line outside your property does not connect into your master socket? Few lines on the Openreach network are ran underground, is this the case?
01-07-2021 7:49 PM
@Gerard_q as an aside, the CWMP logs you are sharing are a result of your problem, not the cause of it.
They are attempts by your router to connect to our hardware management platform, which it cannot do because your underlying broadband connection has dropped.
01-07-2021 7:58 PM
07-07-2021 9:22 AM
07-07-2021 9:55 AM
Thanks for getting back to us @Gerard_q
I'm sorry for the issues with your connection.
I'd recommend raising a fault ticket at faults.plus.net so we can arrange an engineer visit to investigate further. If you can post back once you've reported the fault, we'll make sure that's picked back up as soon as we can.
