Connection dropping, is this normal?
- Re: Connection dropping, is this normal?
04-10-2016 3:41 PM
Is it normal for connection to drop like this. Every speed test I have done it does it on, spoke to plusnet and their answer was to change wireless channels but it does it on every channel. I only signed up in September and thinking of leaving them already as they aren't fulfilling their part of the contract. Never had service this bad before
04-10-2016 4:16 PM
04-10-2016 5:25 PM
Are you in the test socket? It is probably your wireless causing it.
Yes, it is normal.
04-10-2016 6:15 PM
Apparently it is the wi-fi causing it. I have spoken to them again today and been told to go back to Smart wi-fi and see how it goes but it was doing it when I was on that. I feel like banging my head against the wall.
04-10-2016 6:16 PM
Its the worse wi-fi in the world if this is normal, I can get a better connection in the pubs in the town centre.
I can't even use the wi-fi on my mobile phone as its that bad even if i'm within inches of my router, I have to use my mobile date.
