Connection dropping frequently
- Connection dropping frequently
13-01-2019 3:36 PM - edited 13-01-2019 4:32 PM
My broadband drops frequently, often for about 20 minutes. When it happens, I have a flashing orange power light (hub one) and sometimes the broadband light flashes also. This has started happening over the couple of weeks, seems to be getting steadily worse.
Have tried the test socket, 3 different filters, no other equipment connected to the line. Have also factory reset the router a couple of times. This often works for about an hour then starts dropping again. We don't have a landline handset so haven't listened to the line.
We've noticed the problem is far worse when it's windy, and looking at the line from the pole in the street to the house, it seems low hanging and loose in comparison to the neighbours. I wonder if it's damaged and the movement exasperates the interference.
Whilst it's been very windy, I've been unable to connect only for short bursts.
I've submitted a ticket (3 days ago I think) but no response. Could someone please take a look at the line?
Re: Connection dropping frequently
14-01-2019 9:29 AM - edited 14-01-2019 9:30 AM
Hi there.
Sorry to hear you're having issues.
Our tests aren't showing the cause for the problem, but we can definitely see the drops:
Test Outcome | Fail |
Test Outcome Code | GTC_FTTC_SERVICE_1615 |
Description | Potential HR Joint or wet joint detected on GEA Service. Please continue to submit a trouble report |
Main Fault Location | CE |
Sync Status | Out Of Sync |
Downstream Speed | 6.8 Mbps |
Upstream Speed | 0.7 Mbps |
Appointment Required | Y |
Fault Report Advised | Y |
NTE Power Status | Unknown |
Voice Line Test Result | Pass |
Bridge Tap | Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 320.3 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Low |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 15:00 to 17:15 |
Interference Location | Other |
Interference Observed In Days | 12 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Retransmission High - 0.128M-10M Upstream, Retransmission Low |
Time Stamp | 2019-01-01T09:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 7.0 Mbps | 24.9 Mbps | 15.9 Mbps |
Up Stream Line Rate | 0.7 Mbps | 9.9 Mbps | 1.8 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 838.1 Sec |
Retrains | 0.0 | 86.0 | 4.2 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-01-14T08:55:10Z | 2019-01-14T09:10:10Z |
Ingress Code Violation | 11 | 2 |
Egress Code Violation | 1 | 0 |
Errored Seconds | 1 | 0 |
Severely Errored Seconds | 1 | 0 |
Unavailable Seconds | 565 | 343 |
I've checked your account and I can see you started raising a fault, but didn't complete the process, so the fault ticket wasn't escalated to our faults team for review. Based on the information you've given here, I've completed this for you.
While the tests are showing a potential line fault, unfortunately as of very recently most fault outcomes now result in an engineer needing to visit your property for them to be able to trace where the fault lies through end to end testing.
If you can reply to your fault ticket https://www.plus.net/wizard/?p=view_question&id=186317960 with your availability for a visit giving us a nudge here once you've done so we'll be happy to book the appointment in for you as soon as we can.
14-01-2019 9:42 AM
Didn't realise the ticket hadn't gone through. I'll blame the tiny mobile screen 😉
I've replied to the ticket now. Thanks for completing it.
14-01-2019 12:24 PM
