Connection dropping (PPP LCP send termination request)
- Connection dropping (PPP LCP send termination requ...
23-12-2016 5:18 PM
I recently switched from TalkTalk to PlusNet fibre (because of terrible customer service and rising prices at TalkTalk). Since then, I have been experiencing issues with my connection seemingly dropping out. For example, when watching Netflix or iTunes a show will stop playing and report connection problems.
I've had a look at the logs on the router (PlusNet Hub One) and noticed the following, which might give a clue?
16:53:41, 23 Dec.
(681759.600000) PTM over DSL is down after 52 minutes uptime
16:53:41, 23 Dec.
(681759.600000) PPPoE is down after 50 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)]
16:53:38, 23 Dec.
(681756.350000) PPP LCP Send Termination Request [User request]
Anyone experienced similar and if so how did you fix it?
Thanks in advance,
Squizz
Re: Connection dropping (PPP LCP send termination request)
24-12-2016 1:21 PM
Hi squizz,
Sorry to see you're having connection problems. I've been running line diagniostic tests which are indicating a fault.
Can you raise this with us at http://faults.plus.net please? Feel free to reply back when you have and we'll get that picked up.
24-12-2016 2:38 PM
Thanks for responding, I have logged a fault as you recommended.
Look forward to hearing from you.
Squizz
24-12-2016 4:45 PM
