Connection drop on uploads with new fibre router only on ethernet.
- Connection drop on uploads with new fibre router o...
- « Previous
- 1
- 2
- Next »
Re: Connection drop on uploads with new fibre router only on ethernet.
09-10-2016 9:16 AM
No noise i can hear on line...if it were noise connection would just drop randomly anyways would it not?
This stable until upload using the ethernet port.
09-10-2016 9:43 AM - edited 09-10-2016 9:45 AM
09-10-2016 9:54 AM
Thanks for that...was just about to ask if you thought it was router or connection.
And thanks to all who have answered...appreciated
09-10-2016 9:55 AM
Except that it apparently works fine when uploading over wireless, and it's pretty easy for wireless to be faster than 2Mb/s.
So it sounds like an issue with the router to me.
09-10-2016 10:20 AM
Just got it to drop over wireless too.....
Tried for hours last time over wireless and was solid. First time today, failed...
09-10-2016 10:43 AM
06:25:55, 09 Oct. | (392117.480000) PPPoE is up - Down Rate=27610Kbps, Up Rate=2001Kbps; SNR Margin Down=6.0dB, Up=24.3dB |
Definitely worth letting BT check the line, if only to eliminate that as a cause. The line quality isn't wonderful, if it can only manage 27Mbps download at 6dB SNR. Does that match the speed estimate you were given after you signed up? If so, then fair enough, you are a long way from the cabinet, or the wiring under the street is old, or whatever, but if it's a lot less than the estimate then that would tend to suggest that a noisy connection is at least part of the problem.
09-10-2016 12:13 PM
Yeh think the wiring about here is old aluminum. Think the speed is ok...on adsl i got 4-5mb on up to 8mb.. Now im getting 27-28mb on upto 38mb. Ratio wise thats about the same.
Could it take some time after swapping to fibre/vdsl2 to stabalise..I swapped on 30th october
09-10-2016 2:27 PM
No not necessarily, if there isnt much going down the line traffic wise then the errors may be tollerable by the network and can correct with retries / error correction, but when there is too much traffic for it to be able to cope with things like the PPP control messages could get lost and thus force the bt/plusnet end to think the connection isnt responding and then you auto create a new one.
10-10-2016 12:59 PM
thanks...
just wait on bt coming on friday then
13-06-2017 9:33 AM
Apologies for resurrecting this thread, but I have exactly the same issue.
Sekonz, did you come to some sort of conclusion after BT came?
13-06-2017 1:00 PM
Sorry to hear you're having connection problems when uploading.
It looks like this is related to the issues discussed here
I've added your account to the list of affected accounts, so that our products team can investigate this further.
14-06-2017 8:19 AM
No.
I had 3 BT visits. No joy. 3 routers. 2 plusnet routers and 1 other brand. Same issue. Cant upload for without dropping after a bit.
I just do my uploads from work now.
- « Previous
- 1
- 2
- Next »
