Connection downtime
St3
Aspiring Champion
Fixes: 5
Connection downtime
Timeout waiting for PADO packets
Connection dropped for about 20 mins .... is there issues in my area ?
10 REPLIES 10
St3
Aspiring Champion
Fixes: 5
Re: Connection terminated
After 30 mins downtime ive been connected back and now seam to be getting sightly faster speeds, from 64 down to 71 down. I take it BT have upgraded somthing ?
St3
Aspiring Champion
Fixes: 5
MatthewWheeler
Fixes: 479
It's most likely going to have been due to planned maintenance in your area.
 Matthew Wheeler
St3
Aspiring Champion
Fixes: 5
Would you mind checking over my connection to see how stable it is ?
These speedtest sites show me having 71 down / 18 up.
http://www.dslreports.com/speedtest
https://www.thinkbroadband.com/speedtest
And these ones show me having 50 to 55 down / 18 up.
http://www.broadbandperformance.co.uk
https://broadbandtest.which.co.uk
Very confusing... all of them should be reading about the same and from the post above my ip profile seams to have jumped up alittle... will this stay at that speed from now on ?
rongtw
Fixes: 12
@St3 best way is to just test using TBB Thumbs_Up  one only
And No one from Plusnet has answered my post about BT test still borked  Sad
LaurenB
Fixes: 131
Hi @St3 this is how things are looking our end:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 76.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 410.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 13:45 to 13:00
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-02-23T14:30:00
Looking at the connection, it looks like there were a few drops likely due to maintenance as Matt said, this looks all fine now but this could have reset the line causing a profile change.
Just out of curiosity, were those speed tests ran on a wireless connection? As a reset of the router can sometimes cause a an increase in wireless speeds?
 Lauren Barry
St3
Aspiring Champion
Fixes: 5
Hi @LaurenB Thanks for the reply what does it mean by " Regular Interference Observed Daily " ?
Fixes: 1,600
It could be due to REIN (Repetitive Electrical Impulse Noise).
Do you have anything electrical near your router?
rongtw
Fixes: 12
@St3 are you getting interfered with regularly Cheesy
St3
Aspiring Champion
Fixes: 5
@Gandalf Yes i have a phone i will try moving it, also for some odd reason my ip profile has changed back to 67 down Sad I knew it was too good to be true.
