Connection check
Shep41
Connection check
Would it be possible to check my connection,as last night my connection was constantly dropping out. I noticed a few disconnects on Saturday morning . I've checked the router logs and the connection has been up for 6.5 hrs. I would if anything is showing on the radius graph. Event logs are showing 27 drops in just over 4 hrs
Fixes: 78
Re: Connection check
Here's what your connection logs are looking like first of all:
A GEA test (broadband diagnostics) don't show any issues.
I'd give the checks here a go next: https://goo.gl/tu2WWu do keep us posted.
 Adam Walker
Shep41
That's showing 9 disconnects since Saturday. Run through all the checks. Could the router be on the way out?
Fixes: 78
Hi there, it's one a few possibilities, I would advise trying another known working router if that's a concern but I'd only do that if things go as far as us recommending an engineer visit.
 Adam Walker
Shep41
Ok Adam. I'll keep an eye on things
