Connection a bit laggy today, Line check please
- Re: Connection a bit laggy today, Line check pleas...
19-02-2016 12:51 AM
Got a constant solid performance connection at present without a drop for nearly 59 days, the last couple of days i'm feeling it a bit laggy and slow at times. The ping rate is low which is fine but maybe a check to see if there are no performance issues
Message 1 of 5
(953 Views)
4 REPLIES 4
Re: Connection a bit laggy today, Line check please
19-02-2016 4:03 PM
Can't see any obvious issues. What kind of performance are you seeing on a speedtest?
Message 2 of 5
(438 Views)
19-02-2016 6:18 PM
Speedtest is fine 73.50mb down about 17.5mb up, unless it's a dns issue.
Message 3 of 5
(438 Views)
26-02-2016 2:57 PM
Funny thing happened the following day, the wireless internet stopped working and tried my best not to reset the router but to no avail. After 60 days of no drops i had to turn off and on again to fix the issue and all fine again for now.
Message 4 of 5
(438 Views)
26-02-2016 3:12 PM
Nigel, check my new thread... there seems to be a problem with a router / peer in the LINX exchange.... a lot of sites are slow today
Message 5 of 5
(438 Views)
