Connection. Speed In members centre
- Re: Connection. Speed In members centre
02-07-2015 3:30 PM
I'm trying to work out if our alarm is causing issues with our connection speed how often does this refresh ?
We having intermittent drop offs when the phone is being used
Message 1 of 4
(762 Views)
3 REPLIES 3
02-07-2015 3:33 PM
you need to check here for the IP profile as the member centre one only updates every 8 hours or so whereas the one in the link is instantaneous http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
If you are getting intermittent drop outs you need to sort it otherwise the dynamic line management will kick in
Message 2 of 4
(566 Views)
02-07-2015 3:45 PM
Message 3 of 4
(566 Views)
02-07-2015 3:57 PM
Message 4 of 4
(566 Views)
